Results 5,161 to 5,180 of 7102
07-12-2016, 02:22 PM #5161
Great pics! Makes me want to be wrenching again!
07-12-2016, 02:23 PM #5162
07-12-2016, 05:08 PM #5163
I built a garage 2 years ago, so it's not too bad! I wasn't psyched about having to do it for the third time in a year though!
Now I'm working on wasting a set of tires!Long ago...
07-12-2016, 07:07 PM #5164
Moved it to the upper garage so we can load up tomorrow and head out to the Pontiac-Oakland Club National show in Illinois! Anyone else attending?
07-13-2016, 07:37 AM #5165
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
07-13-2016, 07:42 AM #5166
- Sep 2010
- Bel Air, Maryland
I really want to get a set of three point, weld on UMI SFC's on my WS6, I can feel the chasis flex well before the suspension and tires are near saying "uncle" on the on/off ramps. I want to get the car stiffened enough before the front control arms, and the new-ish springs go on.
07-13-2016, 07:46 AM #5167
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
07-16-2016, 06:06 AM #5168
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
07-16-2016, 09:17 AM #5169
00 FB Vert - Stock
07-16-2016, 09:30 AM #5170
I started with 2 points and then swapped to 3 points after we decided to engage in straight line racing with our car. I honestly could not notice a difference between the 2 and 3 points from the driver's seat. There is no question though that the 3 points do tie everything together under the car.
07-16-2016, 09:44 AM #5171
What did you do with your Trans Am today?
i do agree 3pt >2pt> nothing
Just was correcting the thought that they do nothing...
07-16-2016, 10:59 AM #5172
- Sep 2010
- Bel Air, Maryland
Yes, more mounting points = more rigidity. As fat as 2-points being enough for street driving, that might be true but more rigidity will only help the drivng matters on the car. Even if the 3-point is only 5-10% more than the two points, its great insurance, escpecislly for the cabin, take a look at the begining of the "Frankenbird" thread, and you will know why I want the additional rigidity.
I spent a good amount of my past career working in bodyshops and have seen what "a little more rigidity" can do. If there was a 4 or 5-point SFC, and it was a good design, and at a reasonable price point, I would buy it.
07-17-2016, 03:13 PM #5173
- Apr 2010
- Alabama
I wouldn't even consider anything less than 3 point if it were me.
Sent from my HTC6535LVW using Tapatalk
07-18-2016, 04:56 AM #5174
I just had my 3 point SFC's installed a couple weeks ago. I can't compare 2 vs 3 but there's a noticeable difference in performance and ride. They really tightened up the car - well worth it imo. Brakes upgraded as well to slotted rotors , Hawk perf. pads and braided steel lines. Another very worthy upgrade - even more noticeable of a difference from stock. Gotta go Auto-X ing now !!
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
07-18-2016, 05:06 AM #5175
I like the three point but at more than double the price it is tough to justify when only a street car.
2001 Trans Am Vert
07-18-2016, 05:29 AM #5176
- Apr 2010
- Alabama
Test fitted my race star wheels with my CTSV brakes. They fit great. Now I just need some tires.
Sent from my HTC6535LVW using TapatalkLast edited by 98TransAmWs-6; 07-18-2016 at 06:10 PM.
07-18-2016, 01:25 PM #5177
So.....I got around to doing this. I really do like it. It's been painted using that plastidip stuff. Just wanted to see how it would look to make up my mind on getting them Powder-coated like this.
07-18-2016, 01:40 PM #5178
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
07-19-2016, 11:18 AM #5179
Damn Jon! What happened? Where you just driving along and the tensioner pulley exploded?
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
07-19-2016, 12:21 PM #5180
Yikes! That is all tore up. Was that a stock tensioner or an aftermarket piece?
There are currently 14 users browsing this thread. (0 members and 14 guests)
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
