Results 5,141 to 5,160 of 7102
06-30-2016, 07:28 AM #5141
- Apr 2010
- Alabama
Well you might consider changing the fluid with something with the additive mine did something similar and stopped when I changed it.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-30-2016, 10:14 AM #5142
07-02-2016, 10:35 AM #5143
- Apr 2010
- Alabama
Pulled the trigger on some race star wheels 17x4.5 front and 15x10 rear. I just need to figure out tires now.
07-03-2016, 12:24 PM #5144
Brought the Trans Am down from the building after lunch and gave it a bath. Going to drive it a bit this week.
07-04-2016, 12:52 PM #5145
- Apr 2010
- Alabama
Alright so I decided on getting some Mickey Thompson ET Treat S/S 28/12.50r15 tires for the back and Sportsman SR 26/6.0r17 for the front. Should run about $800 to my door but I should be good on traction for when I take the car to the track for the first time after the 421.
07-06-2016, 10:00 AM #5146
Gone for me are the days of having a candle in the headlights (or how it feels like).
My outside lights are fully LED and HID. A how to thread will be done later this week.
Old vs New
07-06-2016, 12:18 PM #5147
Nice SMWS6TA. The output will certainly be enhanced. I would like to do projector retrofits to mine.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
07-07-2016, 11:28 AM #5148Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
07-07-2016, 01:12 PM #5149
Me too! FINALLY!
Monster twin disc installed...long story! AWESOME customer service! I can't say enough good things about Steve Addison! Just AWESOME!
New this spring/summer: poly motor and trans mounts, UMI Trans x-member wither mount for the UNI TA, American Racing Headers (1 7/8"), ARH catted-Y, Borla exhaust with DMH cutout(love the sound of the exhaust through the muffler...old school!), new/reconditioned computer with Frost tune, no more EGR/AIR)
Car is running AWESOME! 100 more miles to go breaking in the clutch and then time for some tire-shredding!
Giddy like a schoolgirl on prom night! (8-PLong ago...
07-07-2016, 07:54 PM #5150
Made a how to thread and sticky so when you ready it's here for you.
http://www.ls1.com/forums/f6/how-bri...id-led-185822/
07-08-2016, 02:28 AM #5151
John - nice work! Certainly have piled on the improvements to your car over the past several months. Don't forget the Chilson-Wilcox event in Gang Mills -- Friday evening before Labor Day. We'll all be there.
07-08-2016, 02:40 AM #5152
Popped the tops and drove the Trans Am to the cruise in last night. Kind of a light turnout as the weather forecast was a bit iffy and it was quite cloudy.
07-08-2016, 07:14 PM #5153
I lowered mine with a lightly pre-owned setup ( Eibach prokit springs, Bilstein HD shocks ). It rode rough after rear spring install. Well here is my order of installments. Rear shocks ( rode fine ), rear springs ( bounces ), front assemblies ( rode slightly better but still bounced a lot ). This is straight line bouncing whenever the car is cruising or accelerating. With concerns of the pinion shaft I have gone easy on the car.
Some after installation photos.
Much too low in the front, but a perfect 'to me' rear stance.
I then installed my on-car adjustable panhard bar ( UMI ), spent some time with my measurements. The car drove much nicer and didn't feel like it drifted badly anymore. Big difference!
Now tonight I went up to Jeff's place ( with Zack too ) and we put in my subframe connectors ( UMI 2pt bolt-in ) and he had some 1/4" aluminum spacers for the front shock assemblies. Getting my car high enough to get the lift arms under it was interesting in its own. We ended up driving over two blocks of wood and Zack lifted the front right from the engine day for the front right arm to get under the car. It was interesting with the three of us working to pull down the wheel enough to gain clearance for the spacers to slide in. I was hanging on the wheels with all the 170lbs I could dangle down with while Jeff and Zack made clearances and guided them in place .
A couple shots of my car on Jeff's blocks he built when he did his 3 points. Sits the car perfectly on its own weight to properly do the SFCs.
We installed the front spacers first. They made the front end sit level with the rear. I am very pleased with the look. The subframe connectors make the car feel more rugged and stronger from just how it feels closing the doors, to taking a tighter turn going down the road. They say the cars should have came factory with them, certainly so! I'm grateful for Pajeff's helping hands and know-how.
In my garage tonight.
I was an extraordinary genius and left my phone on the spoiler as we lifted the car to start the bolts for the SFCs so there isn't an under-carriage shot. So this will have to do.
Now remember the bouncing coming from the rear? After doing this to the car tonight it rides smooth and bounces very little. It almost feels stock again, just a little firmer ( a good thing ) and not sloppy, much more controlled feeling. Now I love the setup. The front being that low must have had the driveshaft at a real bad angle. It was damn close to slammed however. I am glad Jeff had these spacers. I was considering going back to stock. Jeff measured the pinion angles and he came up with a down angle 0.7. Next part will be an adjustable torque arm with drive-shaft safety loop. Of coarse, it will be UMI.
07-08-2016, 08:07 PM #5154
Damn... that car looks hot!
So clean!
07-09-2016, 08:54 AM #5155
- Apr 2010
- Alabama
Can't wait to get these on with tires!They are really light I swear two are lighter than one wheel of the wheels I previously had.
07-11-2016, 09:19 AM #5156
Ordered a new fuel pump assembly. GD fuel gremlin is back.... It's gotta be in the tank because I've replaced all the out side of the tank electrical.
07-11-2016, 07:51 PM #5157
The pump was part of your build, right?
07-11-2016, 08:25 PM #5158
What did you do with your Trans Am today?
I have a Racetronix pump but have been having a random cutout of the pump. Not sure what is the issue, so I'm starting fresh. I think it's something in the wire harness it's self but I can't seem to lock in on it.
00 FB Vert - Stock
07-12-2016, 06:05 AM #5159
Just got it so researching convertible subframe connectors and finding a front plate insert for an 01.
Got a feeling a lot will be done with this car shortly since discovering some of the threads here2001 Trans Am Vert
07-12-2016, 07:29 AM #5160
Welcome to the site, feel free to ask questions, we got a great bunch of ppl here that are willing to help.
Check in the General Help section we have a thread that holds a lot of fix it threads that might help you.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
