Results 4,881 to 4,900 of 7102
03-23-2016, 10:56 AM #4881
With a T56 and 4.11 8.8 rear @ 80mph I see about 2300rpms, in 5th at the same speed it's 3400rpms.
I almost don't need 1st anymore. If or when I hook up nitrous I'm wondering if I should just launch out of 2nd. I really haven't tried anything hard with it yet. Currently on 200 miles of a 500 mile break in. The whole drive train has been upgraded so it's all new. This week was the most miles I've put on it since Nov 2012.
03-23-2016, 11:51 AM #4882
- Apr 2010
- Alabama
Well in my Vette it will tell me instant mpg and at WOT it's been like 8 or 9 mpg lol.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-23-2016, 11:55 AM #4883
It's lying to you -- should be more like 2-3 mpg at WOT. Hell, I get 8-9 mpg pulling my trailer up and down the hills of Pennsylvania.
03-23-2016, 11:56 AM #4884
- Apr 2010
- Alabama
Well my Vette weighs 3000#....
03-23-2016, 11:57 AM #4885
- Apr 2010
- Alabama
That's down from my 33 mpg I get in it on the hwy
03-23-2016, 06:22 PM #4886
03-23-2016, 06:27 PM #4887
I'm going to see how quickly I can go through a tank of gas come spring. That'll be a fun test.
03-23-2016, 08:23 PM #4888
03-24-2016, 03:24 AM #4889
It could simply be a limitation in the system as far as what it will display.
Pulling the trailer up the hill to our house the instant mpg in our Suburban will drop to 5 mpg or less. That is going real slow and well into the throttle. At higher speeds, you are covering a mile in a much shorter time period, therefore, even though the engine is consuming much more fuel it takes less time to travel the distance. It might be right, but seemed a bit high to me.
03-25-2016, 08:01 AM #4890
Finished up the oil change this morning and changed the security system settings (finally) so that the horn does not beep when you arm and disarm the system. Been meaning to do that now for about 8 years.
03-25-2016, 09:53 AM #4891
03-26-2016, 12:12 AM #4892
03-26-2016, 09:27 AM #4893
A little more done! Removed coil pack, cat, and exhaust manifold! It went amazingly well! No stubborn bolts! Manifold bolts done with 3/8" ratchet, cat nuts with impact gun...no struggles, minimal blood!
50,000 miles, still in great shape!
Pretty big weight savings!
Easy to get to the plugs!
And...I can see the floor!
All driver's side!
Next is motor mount, header and plugs!
03-26-2016, 02:38 PM #4894
Always nice when things come apart without pain and fire.
03-26-2016, 08:20 PM #4895
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
My LEDs for the DRLs and side markers came in yesterday so I spent this morning putting new DRL housings in. Replaced the socket on the passenger side and put the LEDs in with the new flasher. Took longer then I wanted but 1 nosy neighbor and a the screws in the housing being stubborn during removal makes for annoying times. Looks so much better and the LEDs are a lot brighter makes the old fog lamp lights look terrible. Guess that and the rear tail lamps will be next on the list of lights to replace. I got switchback LEDs so during the day they are amber but at night with the lights on they turn white but turn back to amber when the turn signals are on. Have to get some pics later this week when the rain moves back out.
03-27-2016, 07:33 AM #4896
03-27-2016, 04:58 PM #4897
Motor mount, plugs and header are in on driver's side!
Old one wasn't too bad!
Pieces!
Used a Dremel brush to clean old bonded rubber from clamshell and Endura grease to seat new poly mount!
I even bled a little!
Not a great pic, but it's all I got for now!
Hopefully get coil pack back in tomorrow!
Passenger side will be the next challenge!
03-28-2016, 01:31 PM #4898
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I set up my appointment to get my car tuned and I am getting it dynoed as well, curious what my before and after will look like.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
03-28-2016, 02:18 PM #4899
What did you do with your Trans Am today?
03-28-2016, 06:44 PM #4900
So after hooking up my e-cutout this morning The family joined in helping me detail clean the bird today. Wash, clay bar, wax and interior cleaning.
She's looking much better.
She's come a long way since I first got her.
00 FB Vert - Stock
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
