Results 4,221 to 4,240 of 7102
07-15-2015, 01:18 PM #4221
Took it for a short run, planning to wash it. Tried getting it to do a stand still but can't seem to. I left it in 1st and let it pull itself, then hit the gas and brake, stalled it. As I have said I don't like the idea of dropping the clutch on a sit-still. Is it programmed factory to not have any spin? I don't have a traction control on/off switch in the console.
2000 Trans Am WS.6 M6
SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
YouTube.com/DarrenWS6
07-16-2015, 03:58 AM #4222
You need to kind of feather the clutch to get the car rolling forward, and lightly push on the brake until the car stops rolling. I rest my right foot 1/2 way on the brake and 1/2 on the gas. Then roll my foot onto the gas. After the rear wheels start to turn, let off the clutch and use your left foot to hold the brake with just enough pressure to keep the car from rolling. Then progressively give it more gas. It will take a bit of practice to get it right. OOORRRRRRR you can get a line lock and really smoke em!! LOL
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
07-16-2015, 12:27 PM #4223
Thanks for the advice. Perhaps I can find a YouTube of it to help with a visual display hahah. I would be interested in a line lock if it is harmless to the brake system and a sime install. All I know about those is they prevent brake fluid from getting to the rear brakes.but the better smoke show and at a faster rate would be nice.
07-16-2015, 01:44 PM #4224
I think a line-lock maintains the line pressure to the front after releasing the brake pedal.
1. Step on the brake.
2. Activate line-lock.
3. Release brake. (Front brakes will be maintained, rears will release!)
4. HEAT 'EM UP😛
07-16-2015, 06:13 PM #4225
What did you do with your Trans Am today?
Yes that is how a line locks work. Not hard to install. About 30 mins to an hr. Hard part is running the wire.
If you get one make damn sure to pay attention to your rpms. Don't bounce it off the rev limiter. Ask me why I have a 403ci build.....http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
07-17-2015, 12:31 AM #4226
07-17-2015, 03:23 AM #4227
If you get a line lock. you will absolutely LOVE IT!! As peeps have said before, it's a simple install, does not affect the safety or function of the stock brakes. Fairly cheap too! The only issue your gonna have is buying new tires. LOL
07-17-2015, 03:37 AM #4228
Check out this complete kit. Summit Racing Part Number:SLE-25000
07-17-2015, 04:50 PM #4229
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Car is loaded and ready for AM trip to Beaver Springs to meet up with Jeff and make some passes....I'm pumped
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
07-17-2015, 05:31 PM #4230
I too am ready for Beaver Springs in the morning. I shall be the only one driving mine down I suppose lol.
07-17-2015, 05:36 PM #4231
Have a blast y'all! I'm jealous!
Long ago...
07-18-2015, 05:23 AM #4232
I wanna see some time slips! Iam super jealous, i am stuck at work. I did go down to capital raceway and watched some good racing. Had a few beers and meet some cool peeps in the spectator area. Weather was perfect last night.
07-18-2015, 09:25 AM #4233
07-18-2015, 09:15 PM #4234
Today my GF and I fixed the moisture in her tail light and replaced a bulb.... That's pretty much it... Oh, and took the '03 Vette out for a ride. We just wanted to check out the Aero Chambers that I had installed on that car last week. Super awesome sound to both the LS1's. But the Vette system sounds better imo.
Life comes at you fast. Grab it and hold onto it with all your might.
Living life in the fast lane. 182IDIE
07-19-2015, 04:40 AM #4235
Our day at the Beaver was hot, humid and absolutely a great time.
07-19-2015, 04:53 AM #4236
07-19-2015, 05:18 AM #4237
Did some cruising! Ordered a line-lock, and install some slim mids from Kee in the back seats! I'll get the Kee components in the doors tonite...if I'm not out driving her!😊
07-19-2015, 08:41 AM #4238
Line lock is so much fun.
07-19-2015, 01:05 PM #4239
Hope there's a giant learning curve for me!😊
One of the big reasons for me to have this is the possibility of long, smoky burnouts! I call it a toy for a reason!😜
Oh, I just got the front components in! Pretty big difference from the Infinitis that had been installed! Lots more bass response and a lot less "tinny" highs! AWESOME! (And highly recommended! Ian Kee knows his shit!😀Last edited by udy2554; 07-19-2015 at 01:13 PM.
07-19-2015, 01:33 PM #4240
I rarely turn the stereo on in our car, but if I ever do pop a speaker I'll be sure to go with Kee.
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
