Results 3,621 to 3,640 of 7102
10-29-2014, 05:53 AM #3621
10-29-2014, 08:24 AM #3622
00 FB Vert - Stock
10-30-2014, 08:56 AM #3623
10-30-2014, 10:45 AM #3624
same here let me know how it goes for you on install. I'm working one gremlin at a time so this is on back burner till it starts to move again.
10-30-2014, 11:54 AM #3625
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-30-2014, 01:04 PM #3626
Why do all you guys want to delete your ABS?
10-30-2014, 01:18 PM #3627
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
10-30-2014, 01:44 PM #3628
10-30-2014, 01:44 PM #3629
I have ABS and a line-lock installed.
10-30-2014, 01:48 PM #3630
3 chl or 4 chl?
10-30-2014, 01:49 PM #3631
4 channel
10-30-2014, 01:55 PM #3632
That's why. Your ABS ring is on the axles so your ABS sensor can read it properly.
With 3 chl it is located on the center section and the abs ring is part of the diff. I counted the ring teeth between my 10 bolt and the 8.8 and the 8.8 had quite a few more. I check with Curtis and he confirmed that it would give a false reading and that my abs would react differently then what it should.
I also have a line lock as well but makes no difference between 3 or 4 chl.
10-30-2014, 02:11 PM #3633
10-31-2014, 03:55 AM #3634
My brother bought a car from "SPAZ" back in FEB or so. He had a Ford 8.8 installed in it, but it had a broken axle on the drivers side. Also the center section was welded together to give it a locked differential. ( Not good for street use at all) We had to buy new axles from MOSER. All we had to do then was install the ABS rings on the axles and ABS is complete! Wasn't that hard to do at all. So now he has 4 channel ABS, a Ford 8.8 with 410 gears, and a stock GM 5 bolt lug pattern.
10-31-2014, 06:36 AM #3635
For me I have a three channel and a Moser 9" it has the reluctor wheel for abs but the sensor is 1/4 of an inch to short so the ABS is INOP. I have drove 4th gens with the ABS deleted and it makes a world of difference, it really wakes up the stock brakes. When I do it I will make a write up with pictures and whatnot.
10-31-2014, 06:54 AM #3636
- Apr 2010
- Alabama
For me it is because I want to set my brake bias and my abs doesn't work to begin with or not well anyways. I'd much rather just delete it with a proportioning valve.
10-31-2014, 06:55 AM #3637
Can you explain this to me a little? I put a 3 channel 10 bolt in my normally 4 channel 10 bolt while my 8.8 is being built and now my TCS and ABS light are on and I worry that I'm going to have issues someway somehow.
I guess I'm asking how it wakes up the stock brakes. What are the differences?
10-31-2014, 10:03 AM #3638
10-31-2014, 11:16 AM #3639
10-31-2014, 01:11 PM #3640
- Apr 2010
- Alabama
Got these for my build to put on my car. The 6.9 is going on the fenders and the 421 on the hood.
There are currently 8 users browsing this thread. (0 members and 8 guests)
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
