Results 3,541 to 3,560 of 7102
08-21-2014, 02:02 PM #3541
My welder makes me look like I can weld... when I am not setting myself on fire. Damn thing makes it almost impossible to screw up a weld.
08-21-2014, 08:09 PM #3542
well with enough Nocor and steroid shots you too can block out the back pain and finish this project too.....
All together, fluids filled, all that's left is to hook battery up and turn key. I'm tired of doing this shit....
08-22-2014, 02:16 AM #3543
Luck is wished.
08-22-2014, 03:32 AM #3544
I was also sceptical about the way you were cutting away at the frame and other structural parts, BUT after seeing the final product....WOW!! looks like a factory piece. The real issue is still the motor mount. As others have already said, it may be a sound piece, but I would be worried about it twisting or flexing out of shape, due to the smaller diameter of the one side of the mount. The integrity of the mount had to have been compromised. Regardless, great work!
08-22-2014, 03:35 AM #3545
I believe the best way to describe your past history as a a carriage worker here in the states would be someone in the USA that would be working for the railroad company. Such as CSX, B&O etc.
08-22-2014, 11:50 AM #3546
I appreciate the positive comments guys!
I WILL tend to the motor mount sometime soon but i am all
worn out from the stuff over the last few days.
I finished the Tunnel brace today and it is wearing a great
gloss black finish Who needs UMI!!!
You have all been a great help with all of the suggestions, advice
and pointers so far in my ownership and long may it continue!!
Going back to the spark plug issue... what SHOULD i get MSD wise
which will offer more clearance at the header tube??
08-22-2014, 01:01 PM #3547
I use the MSD 8.5mm super conductor wires and have had no issues with them.
08-22-2014, 02:51 PM #3548
The trick is to bend the boots on the MSD wires. 0rion taught me that trick back when I installed them on our car. I also installed a set of DEI heat sleeves over the plug ends, but understand that the stock metal shields can also be re-installed.
08-22-2014, 03:07 PM #3549
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
08-23-2014, 02:44 AM #3550
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
08-23-2014, 03:19 AM #3551
- Apr 2011
- Johnstown,PA
I also spent many years (12) building rail cars(7 different types) here in the states. No real title such as coach builder(I like that) we were just welder fabricator's. I put in another 4+ in another shop building man lifts then repairing them. Had to cut apart and reweld finished units right off the assembly line. I became pretty good with a grinder and welder. Now I just do it at home for fun for myself and others who need it. I love doing it now it's not a job
08-23-2014, 04:46 AM #3552
08-23-2014, 06:19 AM #3553
I use Taylor Cable 79603 and slide the stock metal boot over top of the spark plug boot end. It takes some time and some dielectric grease on the wire, but it will fit. The wires have been on my car for well over 10 years now with no issue at all.
08-23-2014, 06:06 PM #3554
- Apr 2011
- Johnstown,PA
Spent the day cleaning for a show tomorrow also checked the Trans fluid and rear end fluid. Also grabbed some picks from under while it was up of the parts I just added
Wanted black but could not pass on the deal
08-24-2014, 05:27 AM #3555
Drove out to a show today...
About 40 miles one way and it drove great on the way there!
On the way back shortly after setting off it started running
like cr*p!! Finally got home after all sorts of hassles and problems
running through my mind, popped the hood and started looking
about only to find the plug lead on #2 swinging in the breeze.
That would do it, eh??
08-24-2014, 03:19 PM #3556
Did it cook the wire?
08-24-2014, 06:39 PM #3557
08-25-2014, 01:06 AM #3558
08-25-2014, 02:55 AM #3559
If it did, you would know it -- either the boot or the wire would be melted or burned.
08-25-2014, 04:15 AM #3560
I get you Jeff, you mean obviously and physically melted and horrid!
I thought you meant somehow electrically speaking causing it not to
play ball due to getting too hot internally in some way?!
Nope.... like i said, all looks fine outwardly and it revved nicely once
clipped back into place!
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
