Results 3,201 to 3,220 of 7102
04-13-2014, 03:56 PM #3201
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
just realized how screwed up my window is
04-13-2014, 05:42 PM #3202
I did something I said I would never do... cut a hole in the floor pan to access the fuel pump.
04-13-2014, 05:55 PM #3203
04-14-2014, 03:19 AM #3204
I never gave it a 2nd thought when I cut my floor out to the fuel pump. If in the future IF I need to upgrade to twin pumps, It will be a 1 min job to get to the pump. No brainer as far as I'm concerned. I know, I hear some of the peeps saying how I cut up my car, but the org car was long gone when I welded in sub frame connectors.
04-14-2014, 05:13 AM #3205
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I have to agree with you on that. I have been selling the original stuff so it's long gone...
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
04-14-2014, 06:15 AM #3206
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-14-2014, 08:57 AM #3207
04-14-2014, 09:30 AM #3208
- Apr 2008
- Madison, WI
-------------------------------------Kooks 1 7/8" race headers, Kooks ORY, Borla catback, Nitto 555R, LS6 intake manifold, Shaner S3 ported stock throttle body, SLP lid, smooth bellows, JAAM Ram Air kit, Elite Engineering catch can, LS6 valley cover, EGR and AIR deleted, Frost tune, and Simpson Racing child car seat in the back. 13.2 @ 108MPH
04-14-2014, 10:21 AM #3209
- May 2013
- Nashville, TN
crawled under my car yesterday and scrubbed the bottom down...cleaned up everything and it looks 1000 x's better. I dont drive my car in the rain, so hopefully it'll last for a while...the guy who had it before me "only other owner" apparently lived down a dirt road because it had some red clay under it that looks like its been there for a LONG time. Still gotta get the engine bay the way I want it, but I hit quite a few metal pieces with polish this weekend and it made them pop big time...really considering a coil relocation kit now.
04-14-2014, 10:36 AM #3210
- Apr 2010
- Alabama
Strangely the undercarriage of my car is clean (relatively anyway) but I have been thinking of cleaning it. What did you use? I was going to have this Black Magic wheel spray I have which works very well on wheel lines but if there is something better I would use that. I am then thinking of using POR-15 on the entire undercarriage for a cleaner look.
04-14-2014, 10:38 AM #3211
- May 2013
- Nashville, TN
honestly, since I have never done it to this car I used dawn soap...which I NEVER and I mean NEVER use on cars. I wanted to get all the grease off the bottom and the dirt...it actually did a great job. I've got some specific spots I need to hit with some spray to make some grease fall off, but other than that dawn did a great job. Did my wheel wells too while I was under it.
since mine looks like it hasnt been done in like 10 years I scrubbed a lot of stuff...you would probably be ok with an actual spray and then just hose it off...I wanted mine to look like it just came out of the factory "not like that is going to happen" but I wanted to get it as close as I could...Last edited by theorangeguy; 04-14-2014 at 10:46 AM.
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
04-14-2014, 01:13 PM #3212
04-14-2014, 02:44 PM #3213
04-14-2014, 03:05 PM #3214
04-14-2014, 03:08 PM #3215
04-14-2014, 03:50 PM #3216
- Apr 2010
- Alabama
Sounds pretty easy. Is there a good way to drain the tank other than pulling the tank? I need to get every ounce of gas out.
04-14-2014, 04:01 PM #3217
04-14-2014, 04:06 PM #3218
- Apr 2010
- Alabama
I guess I could tap a drain plug in the tank as well.
04-14-2014, 04:13 PM #3219
It was real easy to do. I laid it out with tape and drilled starter holes at all four corners. These were then drilled out to around 1/4" for radiused corners and then I cut two parallel slits about an inch long with my die grinder and a mostly gone cutoff wheel. The outer slit was up against the tape and the inner parallel slit was maybe 1/4" over. I grabbed the metal between the slits with my needle nose pliers, bent it up and broke it off to create an opening for an air nibbler. After marking the width of the air nibbler's head on the tape, I drew an outline to follow as you cannot actually see where it is cutting. The only area I had to then cut through with the die grinder is the area at the back where there is a bead rolled in the floor pan. It worked very slick and all the metal shaving stayed on the bottom side, so very easy clean up afterwards. I'll post pics after they upload.
I know. Not one of my prouder moments.
It was the fact that it would be easily accessible that made me finally do it.
04-14-2014, 05:11 PM #3220
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
