Results 2,101 to 2,120 of 7102
05-14-2013, 09:02 PM #2101
awesome, all good points, ive already got a RAM master and slave, but ill pry replace the slave again when i have it out, as it seems its a good thing to do
05-15-2013, 05:41 PM #2102
05-15-2013, 06:33 PM #2103
That looks fuggin' sweet!!!
05-15-2013, 09:48 PM #2104
- Apr 2010
- Alabama
I finished disassembling my short block. The only bearing that looks the least bit questionable is the rear most bearing.
Also does anyone know what these numbers mean?
This is suppose to be a LS-6 block and appears as such but I can't find out what any of those numbers mean and none that I see look like the LS-6 part number I have found on the internet.1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
05-16-2013, 03:45 AM #2105
The block part number is on the back of the block under the driver side head. The P/N should be 12561168.
05-16-2013, 04:23 AM #2106
- Apr 2010
- Alabama
Yeah I didn't see that number any where but none of the other numbers come up with anything either. I will look again later. I guess another way to check would be to measure the bore with a digital caliper, it isn't a ls1 since the valley isn't the same it looks as a ls6 is.
05-16-2013, 05:33 AM #2107
- Apr 2010
- Alabama
Never mind I found it. It is in fact a ls6 block.
05-16-2013, 08:28 AM #2108
The bore is the same for both an LS1 and LS6. Only major revision was a change to the internal webbing as far as I know.
05-16-2013, 09:57 AM #2109
- Apr 2010
- Alabama
05-16-2013, 03:51 PM #2110
I have an office in Ludington that I run. I'm down there a couple times a month. Traverse City is awesome in the summer time. Let me know when you make it up this way.
2000 Trans Am - Sold
BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
2009 Pontiac G8 GT Stock
05-16-2013, 06:18 PM #2111
New lead liner and visor deletes installed. Off to the tint shop tomorrow.
05-20-2013, 05:21 PM #2112
05-20-2013, 05:41 PM #2113
Two days ago. Replaced the O2's, spark plugs, cleaned the MAF, cleaned and oiled K&N, changed the oil. (Mobil 1 5-30) Replaced both hood struts. This , along with replacing the steering column last week takes care of some of my small problems. Took it out for a drove Sunday, and no longer chugs and sputters climbing a hill in 6th at 70. No more SES light either. I found 3 of my plugs were chipping ceramic. Is that bad, or part of the removal?
- - - Updated - - -
05-20-2013, 05:47 PM #2114
The ceramic center cone around the electrode, or the ceramic outer shell that is covered by the plug boot?
05-21-2013, 04:40 AM #2115
The outer shell.
- - - Updated - - -
The outer shell.
05-21-2013, 08:39 AM #2116
Sounds like maybe someone had the socket at an angle, rather than perpendicular to the plug, when they installed or removed them.
05-21-2013, 09:30 AM #2117
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Got it her back from the painter Saturday, hood looks awesome hoping to get inspection later today. As soon as I figure out how to post photo's I will post a few
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
05-21-2013, 12:34 PM #2118
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Ordered a new tranny mount, picking it up tomorrow. Resecured the exhaust, and torque arm setup. Something was moving around and making a contact noise after the tranny/clutch/mc project. Hopefully resecuring everything and the new tranny mount will eliminate that.
05-21-2013, 01:32 PM #2119
- May 2013
- UpStateNY
Midnight Blue- 2001 Trans Am WS6
Bought It!!!!!!
05-21-2013, 08:27 PM #2120
used it to jump start project "ferrero"
There are currently 9 users browsing this thread. (0 members and 9 guests)
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
