Results 1 to 18 of 18
Thread: Cruise Control?
11-24-2010, 06:47 PM #1
Cruise Control?
Ok, mines never worked since i owned it, i need to change this lol what do i need to look at our around to see whats wrong.
11-24-2010, 06:55 PM #2
- Feb 2007
- San Diego, CA
I'm interested in this also as the CC hasn't worked on the 98 since I've owned it. It's the only thing on this car (182,xxx miles) that doesn't work (or that I haven't been able to readily repair).
I fear in my case it's the turn signal stalk (which is the most expensive and most PITA part of the CC to replace).Last edited by 67CamaroRSSS; 11-24-2010 at 06:57 PM.
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
11-24-2010, 06:57 PM #3
Doesnt it have a fuse relay for it, maybe try changing the fuse!!!
11-24-2010, 07:00 PM #4
11-24-2010, 10:29 PM #5
ima try the cheapest first
11-25-2010, 09:45 AM #6
- Apr 2008
- Madison, WI
In my experience with GM cars, its usually the cruise control module box under the hood.
11-25-2010, 03:27 PM #7
11-27-2010, 07:42 PM #8
wasnt a fuse....so next step?
11-27-2010, 11:33 PM #9
11-28-2010, 01:05 AM #10
Try the clutch anticipation switch.
11-28-2010, 01:14 AM #11
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
I'm curious to see what you find out cause mines the same way
12.6 at 112
11-28-2010, 03:08 AM #12
sometimes if you side step the clutch it will hit the clutch switch hard enough to knock it back a few threads. since it is only plastic including the threads it dosn't take much, an it anticipates you stepping on the clutch there for will shut the cruise control off so you don't rev to the moon..
01-12-2011, 09:07 AM #13
mine hasnt worked scents i changed my clutch.. where is the clutch anticipation switch? if thats what u think it is
01-12-2011, 09:26 AM #14
If you have a M6 the most likely problem is switch that is located just behind the clutch pedal at the top.
It goes for about $19 on gmpartsdirect.com
You can see it in this diagram
It is the first place that needs to be checked. Also the break pedal has one too. These are made of cheap plastic and with the constant action of pedal in and pedal out it becomes brittle over time.
01-12-2011, 09:37 AM #15
ok ill check it out thanks
01-12-2011, 07:54 PM #16
wish it was a m6 =(
for sale in MARCH 2011!!!!! probly be at 131k miles
01-13-2011, 03:06 AM #17
so did you ever figure out the problem??
01-13-2011, 08:55 AM #18
Help: cruise control
By a70oldscutlass in forum Firebird / WS6Replies: 5Last Post: 07-08-2015, 02:41 AM -
no cruise control
By 1MileCrash in forum Stereo and ElectronicsReplies: 5Last Post: 07-11-2013, 10:54 AM -
No Cruise Control
By oharam in forum General HelpReplies: 8Last Post: 03-01-2011, 08:53 PM -
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
Cruise Control on New TB
By navyLS1 in forum General HelpReplies: 1Last Post: 01-01-2010, 12:44 PM
