Results 41 to 60 of 113
Thread: My Head/Cam Install
10-22-2010, 09:01 PM #41
10-22-2010, 09:07 PM #42
10-29-2010, 08:07 PM #43
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
Christmas came a little early this year boys ......
ups man finally showed up!
Still waiting on cylinder heads and injectors. A few questions?
1. Which color O ring do I use. I got the melling pump and theres a choice between a green and black?
2. What do I use to clean the cam? It seems to be pretty dirty.
3. The inside of my LS6 intake is pretty oily. Is there a way to clean it out?
4. The lifter instrucions talk about preload? Basically I want to know how to install the cam, the lifters, pushrods, and rockers the correct way. How do I torque the rockers etc...
5. Do I need to use RTV if I got a new front cover seal?
6. Which bolts do I need to apply loctite to?
Thanks for all the help everyone!!!!!
10-29-2010, 09:46 PM #44
read this book called "how to build and modify GM LS series engines" by Joseph Potak. besides being an awesome read, it answers all of your questions just asked above and there's pictures to go with each instruction (helpful for retards like myself)
10-30-2010, 05:42 AM #45
10-30-2010, 01:33 PM #46
- May 2007
Trick Flow as Cast 220cc milled 61cc, 228/230 .588/.592 112 LSA Camshaft, 11 to 1
10-30-2010, 02:54 PM #47
10-30-2010, 03:51 PM #48
there's not alot of good literature out there for fbody/ LS1 cars but all the same I try suck up as much as I can. i think more than half the questions asked by people on this board would have not been typed if they had bother to go to the local book store or amazon.com.
I've found 2 very helpful books and 2 alright books at barnes and noble of all places.
10-30-2010, 05:56 PM #49
- Oct 2010
- jacksonville, florida
red- 02 camaro/ls7
Lloyd's LS7 Camaro
I have completed building two ls7 engines the one with titanium rods I used
kaytech bolts, however these rally pulled the rods out of round so had to resize which was $125.00 more so thats $325 in rod bolts.So if it is not high mileage motor just use new head bolts (ARP) and enjoy.
11-01-2010, 07:35 AM #50
- May 2007
Do I need new lifter trays? Also what is the best cam and lifter lube you can buy locally?
11-01-2010, 09:20 AM #51
11-01-2010, 10:10 AM #52
- Oct 2010
red- 02 camaro/ls7
ls7 build
I use Torco assembly lube, as for cleaning cam brake clean will work for first clean and then use automatic trans fluid to clean lobe and bearing surface
this should be wiped clean again and third apply Torco lube as you assemble.
Do you still need valve adjusting info?
11-01-2010, 10:55 AM #53
- Jan 2006
- Shepherd, Michigan
i have a feeling you will become a very valuable member of this community lloyd
11-01-2010, 12:09 PM #54
11-01-2010, 05:38 PM #55
- Oct 2010
red- 02 camaro/ls7
I can only agree with others on books I have been reading and reading. I bought some
shop manuals off Ebay on Camaro 2000 year books and my car is 2002 but 99.9 of
what I need will be covered, think all three were about 85.00 used I can email you a few pages if you like on cam install...
11-01-2010, 07:54 PM #56
- May 2007
well when you look at ls1howto it seems really simple I mean it doesnt really go into any detail. but yeah if you wanna email me some info that would be great.
11-06-2010, 07:42 PM #57
- May 2007
Update. I got the motor mounts installed. It really wasnt that hard with the engine stripped down as much as it is at this point. The scissor jack method to getting the pass bolt back in is great! I got the new trunions installed with just a few tools that most of us have. Its a great upgrade to the stock rockers and relitivaly cheap. My svo green tops just came in so all im waiting for now is the heads and the pushrods. I have no idea when they will come in but im hoping soon. I ordered them on the 4th of October...
11-10-2010, 10:35 PM #58
Ordered them on the 4th and still not here dam. I got a ms3 cam from a friend since I just.got a stall and ordered the patriot spring kit, jp double roller timing chain, manley rods, and a slp high flow oil pump since it was in stock and I.ordered them on a wed and they got to my friends shop that Friday and dropped the car off last Monday and should be tuned annd ready tomorrow. Gotta find a better vendor if parts are taking that long. I usually use the ws6store since I got all my bolt ons and suspension from them so they usually knock the prices down and ship it for free.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
11-13-2010, 05:06 PM #59
You get your heads yet, hows it going?
11-14-2010, 03:49 PM #60
- May 2007
Heads will be here tomorrow! Have a question though. I saw someone use a 220 grit sand paper block to clean the block deck. I uses this method as well, but I have not seen anyone esle do that. Did I damage the block deck? Also any tips on how to use the comp cams pushrod checker? Thanks!
Question: Cam and Head Install
By 1slowbusa in forum Internal EngineReplies: 4Last Post: 01-20-2011, 12:30 PM -
Stock Head Unit System or install custom head unit?
By ibh182 in forum Stereo and ElectronicsReplies: 3Last Post: 06-16-2007, 09:43 AM -
need some help after Head and Cam install
By cm2papa in forum General HelpReplies: 17Last Post: 05-11-2007, 10:59 AM -
head and cam install
By waldo31031 in forum Internal EngineReplies: 1Last Post: 02-17-2006, 02:03 PM -
By waldo31031 in forum Internal EngineReplies: 1Last Post: 02-16-2006, 05:58 PM
