Results 21 to 35 of 35
Thread: Internals of a Catch Can???
12-06-2010, 11:57 AM #21
12-06-2010, 12:36 PM #22
Ive seen a polished one in person before. A guy got one for his turbo kit he got off ebay. They arnt that big. Im not sure where yet though. Gotta get it here and mock it up and see where it will look good and mount correctly while doing its intended job. But im sure i can find a good place. I still have an EGR/AIR setup on my car so setting it up off the passenger side head is probably out.
12-07-2010, 06:06 PM #23
first i've heard of these? what are they good for?
12-07-2010, 08:55 PM #24
12-08-2010, 01:57 PM #25
12-08-2010, 02:22 PM #26
The term "blow by" is originally referring to a case of worn rings that allow cylinder pressure past the rings and into the crank case, and the excessive pressure pushes oil up through your pcv breather system. This is not what a catch can is designed to cure. The motor is in need of a rebuild.
In the case of the LS1's, it's a simple matter of a poorly designed pcv system that actually sucks the oil into the intake track. Has nothing to do with worn rings. In which case a catch can is a worthy addition.
12-08-2010, 02:32 PM #27
soooooo, yes get one? It is Christmas time
12-08-2010, 02:33 PM #28
12-08-2010, 02:39 PM #29
Yep, it helps to keep oil out of the intake track which ultimately means, out of the combustion chambers.
Oil in the combustion chambers delutes the fuel charge, causes detonation, coates the intake valves as well as the intake runners and the inside of the intake itself. It kills HP in extreme instances.
There,,,,have I scared you into buying one yet??
12-08-2010, 02:39 PM #30
im scared and i already bought one lol
12-08-2010, 02:40 PM #31
12-08-2010, 02:41 PM #32
finding this thread the other day already made me want to get one. need to spend some time on the car anyways, my DRLs just went out the other day, both on the same day (weird)
12-08-2010, 02:44 PM #33
12-08-2010, 02:52 PM #34
12-08-2010, 03:56 PM #35
For Sale: LS1 block and internals $400
By 98TransAmWs-6 in forum Parts For Sale / TradeReplies: 4Last Post: 04-07-2014, 10:51 AM -
Balancing the Internals
By Naaman in forum Internal EngineReplies: 3Last Post: 02-26-2011, 05:21 PM -
Forged internals for FI
By 35th-ANV-SS in forum Forced InductionReplies: 127Last Post: 02-21-2011, 06:00 AM -
Why not Eagle Internals?
By oreowizard in forum Internal EngineReplies: 8Last Post: 12-28-2007, 06:26 PM -
402 with 427 internals
By deception05 in forum Internal EngineReplies: 4Last Post: 09-26-2005, 03:07 AM
