Results 1 to 15 of 15
    Yorkville, Illinois
    Silver / black
    95 Z28
    Strange rpm jump
    Hey guys, just put headers on my roommates 02 v6 firebird. She also has slp cold air induction. Ever since the headers have been put on, sometimes when she accelerates hard in 3rd and 4th gear the rpms will shoot up to 5k then come back down and accelerate normally. It feels like shes spinning the tires but the tires arent spinnin out. It feels and sounds like the trans pops out of gear but according to where the shifter is, it shows it's in gear? It didn't do this befor the headers. Could this be a trans issue? Or maybe needs a pcm tune? Any input would be great!
    Apr 2009
    Palm Desert, CA
    97 3.8L Firebird 5 Speed
    did you get the car tuned after the headers were installed?. It is pretty much required to make the car run right
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by Conflict View Post
    Are you sure about that?
    I don't know about V6's, but there are plenty of people on this forum that have had LTs installed on their LS1's WITHOUT a tune and have been fine. I don't think it's required, but it is recommended to get the most HP/TQ from the change.
    Sounds like the transmission is slipping to me. This happened right after the LTs were installed? Is the car an auto? Any codes?
    Apr 2009
    Palm Desert, CA
    I know someone with a 4.6 mustang who had to have it tuned to run right, I don't know anybody that has put headers on the 3.8
    also were the gaskets installed properly?, maybe some type of leak
    NeW YoRk
    2001 ws6
    a tune is not required, however, to get the proper performance out of the car you need a tune. its only doing it in 3rd and 4th?
    A tune is not required after a header install. Your car will run rich, but will run fine. You will get optimal performance with a tune, but again, a tune is NOT necessary after a header install.
    Apr 2009
    Palm Desert, CA
    I figured you had to, everyone I've met has always tuned afterwords
    Yorkville, Illinois
    Silver / black
    95 Z28
    yeah its only doing it in 3rd and 4th. My guess is trans, it's a 5spd and shes a little rough on the clutch in my opinion, I am going to look into getting a tune just to see if it makes a difference otherwise I will assume it is trans related. She says it's been slipping oiut of 2nd alot lately so it may be time to just break down and replace the clutch. Yeah I checked gaskets and they are fine, checked where the headers meet the y-pipe for leaks and where the y-pipe meets the cat.... nothin to be found. Thanks for all the input, if you think of anything else....lemme know
    Yorkville, Illinois
    Silver / black
    95 Z28
    P.S. anyone recommend anyone in particular for a tune?
    Apr 2009
    Palm Desert, CA
    The Frost Tune is good for the LS1 F-bodys, but I am not sure on their 3.8 work
    sounds to me like she might be due for a clutch but that's a guess
    Pittsburgh
    2008 Hummer H3
    This.... and/or the headers maybe boiling the slave fluid..
    Yorkville, Illinois
    Silver / black
    95 Z28
    having clutch replaced today/tomorrow.....will see what happens....
    Nah clutch is saying FML. If the fluid was boiling she'd be having issues shifting and or pedal sticking to the floor.
    Pittsburgh
    2008 Hummer H3
    I gotcha.
  1. STRANGE,STRANGE Trans Ams
    By fbodyNATION in forum Firebird / WS6
    Last Post: 08-27-2013, 03:29 PM
  2. can u jump like this
    By xmb1993 in forum Multimedia Section
    Last Post: 05-05-2010, 10:07 PM
  3. Someone should jump on this.
    By bluefields88 in forum Camaro / SS
    Last Post: 11-08-2008, 12:08 PM
  4. VW van jump
    By LETHALxLS1 in forum Almost Anything Goes
    Last Post: 03-24-2008, 08:02 PM
  5. Keep having to jump my SS
    By 600rwhpSS in forum General Help
    Last Post: 01-05-2007, 09:36 PM
