Results 1 to 20 of 38
Thread: EGR Question
    Member Pickle86's Avatar
    Apr 2009
    kanas city Mo
    2000 Trans am ws6
    EGR Question
    so im going to be installing headers soon and i have a 2000 ws6 so i have the ls1 intake. anyway i want to get rid of the whole egr system but was wondering if i get rid of it will it run ok until i get it tuned?
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Yep it will throw a code but I know people running headers and an ls-6 intake for over a year and still fine.
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    Yep, I removed on my 2000 and it ran the same, no noticeable difference except for the SES light.
    2000 WS6 TA #2946 - A4, Best 1/4: 12.5s @111mph.
    SLP LTs, 228r Cam, SY 3500, Shift kit, LS6 intake, underdrive pulleys, lid, p&p TB, Borla w/ cutout, Pro-kit springs, poly all around, Hotchkis suspension, 3.90 gears, tuned.
    Apr 2009
    kanas city Mo
    2000 Trans am ws6
    Quote Originally Posted by 666ws6 View Post
    ok cool i was thinking i would just get rid of it. thanks for the replies guys.
    Greenville, SC
    The toughest part for me was finding the expandable plug for the intake.
    Any local auto part store should have it, ran me about $3 for one.
    Senior Member JoshuaGrooms83's Avatar
    Lake Geneva, WI
    98 Trans Am
    WHat does the EGR really do anyway? I still have mine hooked up and running on my new OBX headers, but I dont quite understand it.
    Quote Originally Posted by JoshuaGrooms83 View Post
    http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
    "EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. In a gasoline engine, this inert exhaust displaces the amount of combustible matter in the cylinder. This means the heat of combustion is less, and the combustion generates the same pressure against the piston at a lower temperature. In a diesel engine, the exhaust gas replaces some of the excess oxygen in the pre-combustion mixture.
    Because NOx formation progresses much faster at high temperatures, EGR reduces the amount of NOx the combustion generates. NOx forms primarily when a mixture of nitrogen and oxygen is subjected to high temperature."
    Lake Geneva, WI
    98 Trans Am
    So in all, it just aids in cold start and reducing emissons in the first, um 5 minutes of the car warming up?
    So in all, its fairly worthless. Thats probably why GM did away with it after the 2000 models.
    Lake Geneva, WI
    98 Trans Am
    OK, but if i still have it in there it doesnt really hurt anything right? its all hooked up and doing whatever its suppose to be doing.
    Its not hurting anything.
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Is the intake manifold plug the only plug you need if you have headers that don't use the egr
    Quote Originally Posted by jetaws6 View Post
    Yes
    Greenville, SC
    Once you take it out, you will be surprised how nicer the engine bay looks, and the weight savings can only help, even if only 20 pounds or so.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Could a GM dealer get rid of the code thats thrown?
    Lake Geneva, WI
    98 Trans Am
    probably, but you'll probly end up paying dealership price
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Not when you know people that work there
    98 T/A w/ mods, 00 FBVert
    Check Tune by Frost (Sponsor Member)
    Once you put on LT's you will must likely delete your CATS and rear O2's His tune fixes these and also frees up some hidden HP. Very affordable and well worth it.
    Lake Geneva, WI
    98 Trans Am
    Oh well in that case as you were
  1. speedometer question + top speed question
    By Krazy351w in forum General Help
    Last Post: 06-21-2007, 05:51 PM
  2. HPIII question (not the same old question)
    By slims00ls1z28 in forum Computer & Tuning
    Last Post: 06-01-2007, 04:55 PM
  3. 97 Bird Headlight question also engine noise question
    By Zapper2003 in forum General Help
    Last Post: 12-13-2006, 03:03 AM
  4. Speedometer question, RPO question
    By acrylicophobia in forum Firebird / WS6
    Last Post: 11-02-2006, 07:08 AM
  5. Sex Question spinoff- PORN QUESTION
    By egaian in forum Almost Anything Goes
    Last Post: 07-26-2006, 03:07 PM
