Results 21 to 38 of 38
Thread: EGR Question
03-19-2010, 04:54 AM #21
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
ok so thread from the past is back for my quick question..i bought headers they do have egr fittings but my car is an 02, so i will need to weld 2 plates tho those fittings but no gaskets? and i will also need a egr plug correct?
03-19-2010, 05:38 AM #22
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
I have a question about this as well i just installed the fast intake manifold and i blocked off the egr down by the header now the sensor is just hanging there.. Where is that sensor "supposed" to go once that tubing is all gone??? the car seems to be running sluggish wtf????// Help
03-19-2010, 06:47 AM #23
What side of car are you referring to in regards to the sensor? There are no EGR sensors on the drivers side, there is a coolant temp sensor near the headers that is just behind the power steering pump. That does need to be connected. For the wire harness for the EGR, I just tucked it away as best as I could and wrapped some electrical tap to protect plug in case of need later on.
03-19-2010, 06:54 AM #24
03-19-2010, 07:05 AM #25
03-19-2010, 07:16 AM #26
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
03-19-2010, 07:19 AM #27
03-20-2010, 11:44 AM #28
- Jan 2010
- texas
silver- 2000 formula
03-20-2010, 11:44 AM #29
- Jan 2010
- texas
03-20-2010, 11:45 AM #30
- Jan 2010
- texas
03-20-2010, 11:45 AM #31
- Jan 2010
- texas
03-20-2010, 05:22 PM #32
- Apr 2008
- Madison, WI
sjsingle1, you rock at posting kick ass pictures! Keep up the good work.
03-20-2010, 06:59 PM #33
- Jan 2010
- texas
any 1 can write.......but the pic tells the story
03-20-2010, 07:07 PM #34
Sjsingle1- that's the egr block off I bought as well. Kinda' expensive but I wanted it to look factory. Hit mine with some matte black to hide it. BTW- you do take some killer pics, what type of camera you using?
03-20-2010, 07:11 PM #35
- Jan 2010
- texas
its just a sony 7.2 MP....bought it a while back.......now every thing is 10 MP......and I was going the expandable rubber freeze plug route......but I had ordered the GM plug.....if it had not come in time.....my dealership takes forever to get special orders in.....if it had not come in on time I would have had to use that rubber plug
03-22-2010, 08:52 AM #36
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
The fast 92 mani already come blocked off i'm trying to find the other block off that sits down by the header (passenger side)
03-22-2010, 08:59 AM #37
If you're talking about the metal plate that goes over the inlet, you can make those really easily. Go get a peice of metal stock from Home Depot and then use the EGR/AIR pipe that you take off as a template. Did the same thing on my old motorcycle when I removed the AIR from it. Took about 20 minutes. You can just reuse the gaskets and bolts that are already on there.
03-22-2010, 10:01 AM #38
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
