Results 21 to 40 of 99
Thread: 01 cobra vs. 00 Z28
01-17-2010, 07:08 PM #21
Since no one seemed to read my comment I will say it again sticky tires on a stock stall is going to make you bog.
01-17-2010, 07:20 PM #22
better street tires if sticky tires wont work with stock stall.
01-17-2010, 08:10 PM #23
01-17-2010, 08:41 PM #24
01-17-2010, 09:21 PM #25
01-17-2010, 11:39 PM #26
01-18-2010, 03:01 AM #27
Yes the DR's will cause you to bog. You need to be launching at a higher rpm to take advantage of the DR's and the stock stall will not allow that. The moment you hit the gas, the car will bog down and it will cost you some time. DR's work with a stall.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
01-18-2010, 04:30 AM #28
- Jan 2007
- Knoxville, TN
B2300 (Fluffy) Retired- Plain-Jane Dodge Truck
I read your comment, and simply ignored it, but now that you are bringing it back up, could you 'splain somethin to me please? Great. Picture this...
You're at the line....one foot on the brake, perhaps the other foot on the gas. You've got the engine rpm sitting at ~1000. Yellow lights come down. At the perfect moment, you let off the brake while simultaneously mashing full throttle on the gas. You have good tires and they don't spin at all....
At this point, given that we're talking about an A4 and not an M6, how on God's green earth do the rpm go DOWN?
LeadFarmer....come to this forum for entertainment, but don't get tech advice here - the "A4 bogging" is the perfect illustration why. At the VERY LEAST go to the tech forums on this sight, and if you're serious, I'd go to the site I recommended earlier in this thread.
01-18-2010, 05:22 AM #29
What Bob said on LS1tech.com There is a ton more people that actively post and a wealth of knowledge there plus a plethora of quick cars running sub 9's. They can point you in the right direction.
01-18-2010, 05:39 AM #30
drag radials causing you to bog is one of the silliest things i've heard in a while. spinnin aint winnin.
01-18-2010, 07:07 AM #31
- Jan 2007
- Knoxville, TN
In fairness, you can certainly bog an M6....but an auto???
One other quick point...once again in all fairness....there certainly are knowledgeable and fast folks on this site, I just think that for 'how to go fast' tech, you can do better over there.
01-18-2010, 07:17 AM #32
An auto will bog on the line if you have a stock stall, 2.73 gear and a DR depending on the launch. There is a thread on LS1tech that talks about that. One way to change that like I said before is a stall or even changing the gears will help to a 3.42 or 3.73.
This guy is one
http://www.ls1tech.com/forums/nitrou...ite-plz-2.htmlLast edited by 98Hardtop; 01-18-2010 at 07:19 AM.
01-18-2010, 07:33 AM #33
take a look tru this link
http://www.ls1.com/forums/showthread.php?t=61330
the best thing you can do is go to the track and get seat time and just try new stuff till you find what works for you
01-18-2010, 07:43 AM #34
- Jan 2007
- Knoxville, TN
That does not answer my question above about how an A4 can "bog". So long as you floor the gas, with an automatic - even with a stock converter - the rpm is NOT going to drop down when you release the brake.
Now...certainly a stock converter can result in a very lazy launch, as a tight stock converter won't allow the engine to get into the meat of the powerband quick enough to produce good 60 fts....but that is not a "bog".
I would add that if you spin off the line, allowing the rpm to climb, then the tires get traction, that could be considered a "bog". But if I have a sticky tire that prevents the tires from spinning, then this "bog" scenario never takes place - hence my point.
There is, however, some good info about adding a looser converter with 2.73 gears in that thread.
Concur with 01 T/A.
01-18-2010, 08:16 AM #35
- Jan 2010
- Arlington,Texas
Silver/Black- 00' z28-R.I.P 00' WS6 M6
ight cool, thanks for the help guys i'll be sure to check out ls1tech
01-18-2010, 08:51 AM #36
- Jan 2007
- Knoxville, TN
Good luck to ya!
01-18-2010, 09:19 AM #37
- Jan 2010
- Arlington,Texas
my friend should be back from A&M in a month, I'll be sure to let yall kno how stuff goes, we'll both prob put up a vid of it too except his will be up on svtperformance.com
01-18-2010, 10:25 AM #38
01-18-2010, 11:38 AM #39
01-18-2010, 12:39 PM #40
- Jan 2007
- Knoxville, TN
ROFLOL.
Ahhhh.....this is what keeps me coming back to this forum!
04 cobra vs 04 gto
By burnsxxxls1 in forum Kill StoriesReplies: 22Last Post: 04-26-2010, 05:14 PM -
2008 Cobra Jet Mustang - Return Of The Cobra Jets
By Ed Blown Vert in forum Almost Anything GoesReplies: 1Last Post: 05-27-2009, 08:16 AM -
Ford 428 Cobra Jet Build - Deadly Cobra - Engine T
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-17-2008, 10:40 AM -
03/04 Cobra(Cobra-R wing) and Screamin Eagle V-Rod
By Stone in forum Kill StoriesReplies: 3Last Post: 05-02-2008, 12:14 PM -
Cobra's Wow!
By camarojunky74 in forum Domestics and ForeignsReplies: 201Last Post: 08-31-2007, 05:11 PM
