View Poll Results: Your HD Choice (You can select more than one)
- Voters
- 40. You may not vote on this poll
Shotgun
24 60.00% -
Rifle
11 27.50% -
Pistol
32 80.00%
Multiple Choice Poll.
Results 81 to 100 of 100
Thread: Home Defense
01-06-2010, 05:48 PM #81
01-06-2010, 05:57 PM #82
01-06-2010, 06:05 PM #83
01-06-2010, 06:54 PM #84
Kahana, doesn't Cali have a magazine capacity limit? Like 10 rounds or something? If it's 10 rounds, this would negate one of the big benefits of a semi auto over a revolver. I'd have a hard time shelling the money for a Springfield XDm 9mm and only getting 10 instead of 19.
01-06-2010, 07:26 PM #85
- Aug 2007
- Texas
XD compact is an awesome gun...the full size is too big for me, and it holds 10 45 rounds standard.
plus, like many have said....if after 10 rounds of .45 goin off at close range, you still haven't hit your target AND the sound didnt scare them off....I don't think its gonna matter anyway
01-06-2010, 07:40 PM #86
01-06-2010, 07:41 PM #87
01-06-2010, 07:45 PM #88
01-06-2010, 10:34 PM #89
KR,
I have the S&W 38 Airweight hammerless. I suggest taking one for test run at the firing range. They are not smooth by any means. They are light and they do kick in your hand. It may be a feeling you might not like. They are loud too but that's a good thing in order to scare your attacker off. It's small enough to hold close to your body between you and the attacker in case of a close attack and always ready to fire at the pull of the trigger. With revolvers, you don't have to pull the slide back to chamber a shell first. Ammo for the 38 is either +p or not. If it's a 38+p then you can fire +parabellum and regular 38 ammo. If your 38 is not a +p then don't load 38 +p ammo in it. Be sure to ask your gun dealer about it.
Look into a S&W snub nose 357 to take for test run also.
01-06-2010, 10:44 PM #90
01-06-2010, 11:13 PM #91
01-07-2010, 04:34 AM #92
- Apr 2006
- Charlotte, NC
Hugger Orange/W stripes- 1999 Z28 M6
Ed gave you great advice when he mentioned the importance of practice.
You'll drive yourself silly-crazy trying to cull the list of capable handguns down to one. I myself tend to prefer automatics over revolvers, but that is not to say I dislike them. It's just a preference and mostly based on a duty-carry situation where additional ammunition and quick reloads are important factors. In your original post you mentioned getting a revolver, so I'd like to just stay specific to that with my suggestions. Here goes!
Buy a double action .357 with a 4" barrel. In order of preference my choices would be; S&W, Colt, Ruger, Taurus, Dan Wesson. There are other models out there, but those are some I recommend (although Dan Wesson might be a stretch for home defense only). Like I mentioned before, any .357 can fire 38 Special ammunition. This makes it more versatile. The down side will be a little heavier weapon (although that differes amongst makes). For instance, S&W FORGES their frames while Ruger uses INVESTMENT CASTING. Both are strong, but the S&W will usually have less metal and therefore less weight. In a .357, S&W will have three main frame sizes to consider "K" ("standard"), "L" (slightly larger), and "N" (largest). There are some highly specific models (including titanium) that you could buy, but they are very expensive and not really worth the cost for a home defense gun. For a woman's gun, I'd rule out the "N" frame. I have a Model 27 and I don't think most women would prefer the size of that gun. While you can get custom grips for a smaller hand, the frame is still somewhat massive. That leaves the K and L frames. The big advantage of the L frame (a model 686) is added durability and a heavier muzzle due to the full length barrel lug (the metal that is under the barrel). This helps to reduce muzzle rise with full power loads, making follow-up shots a bit faster. Still, it adds weight. Now we are down to the K frame. A model 66 was the law enforcement iconic handgun. A man names Bill Jordan had a lot to do with that model becoming very popular. Google him sometime for an interesting read. My very first duty gun was a model 66, and it was a shooter. Very few female officers were on my department, but I only remember one having issues with the weapon because of its size (and she was a complainer anyway).
A "double-action" means that the weapon can be fired with a long, heavier trigger pull that manipulates the action to "cock" the hammer through the pull and release it at the end, AND the weapon can be manually "cocked" by pulling the hammer back into firing position manually (with the thumb) which greatly lightens and shortens the trigger pull. Single action firing is more useful in situations where the best accuracy is needed. It has the drawback of a much more sensitive trigger release which can be a problem in a tense situation, increasing the chances of an unintentional discharge of the weapon. Double action firing is more deliberate. In most self-defense situations, double-action is the way to go. A double-action design gives YOU the choice. A single-action design (Ruger Blackhawk revolver, Colt 1911 semi-auto are examples) requires that the weapon be cocked manually before the first shot can be fired (and every following shot in the revolver design, but not the semi-auto). There are some double-action ONLY (DAO) weapons out there too, and these will have shrouded or "hammerless" designs where the shooter has no physical means to "cock" the gun. I carried a S&W 4046 that was DAO. It was okay, but designs like the M&P, Glock, and some others have a superior trigger pull and accomplish the same thing with much less weight. I bought that gun when it was "retired" and it is a boat anchor compared to my subsequent Glock 23 and S&W M&P.
One last thing about S&W. The number "6" is an important indicator for most of their models. In MOST cases, it indicates the model is made of stainless steel (example: model 66 is a stainless K frame .357, while a model 19 is a carbon steel K frame .357. Both are exactly the same gun except for the metal that makes up the frame, barrel, trigger, and hammer). Just FYI.
Most self-defense situations are over within three rounds being fired. In MOST cases, a six-shooter is more than enough. Firing inside your own home, you will likely fire as least amount of rounds as is needed. A speedloader or two can be available, if needed. That reminds me of one downside to consider with a revolver. While a semi-auto can be rendered "safe" by means of a lever, empty chamber, no magazine inserted, etc., a revolver that is loaded is ready to go boom with just a trigger pull. This can be a concern with unauthorized handlers (kids, curious adults). If you have a loaded revolver readily available, it is only one trigger pull away from firing. The simplicity of that design is both an attribute AND a liability. Something to consider as well.
I suggest you seek out local gun ranges to see if they "rent" guns for use. That can be a quick way to find out what you prefer. Another possibility is firing the weapons of friends that you think might be the ticket. In any event, when you finally choose a handgun, make sure you practice, practice, practice! You will perform the way you train. Don't be shy about seeking out adivce from those who know what they are talking about (and be wary of those who talk a lot but don't instill confidence). Do NOT skimp on practice.
I'll go out on a limb and give you a specific suggestion for a gun to purchase:
S&W Model 66, 4", and buy aftermarket grips that feel comfortable to you. Load it with Winchester .38 Special 158 gr. SWHP +P ammuniton for home-defense and buy 158 grain loads for practice. You will have a good, reliable weapon with good stopping power that will be easy to learn, fire, and maintain.Last edited by jad628; 01-07-2010 at 04:38 AM.
01-07-2010, 08:54 AM #93
Wow... Thank you for that! That is very helpful information and advice. I printed it out.
01-07-2010, 12:27 PM #94
- Jan 2008
- heart of dixie
06 Jeep Grand Cherokee.- 02 superchipsZ28 M6(sold)
the wife has a ruger sp 101 .357mag next to her i have a 9mm ar-15 carbine with two 32 rnd clips.
01-07-2010, 01:44 PM #95
- Nov 2005
- Missouri
Torch Red- 1999 Corvette Hardtop
My main in home defense weapon.
01-07-2010, 01:50 PM #96
01-07-2010, 02:44 PM #97
01-07-2010, 02:51 PM #98
Looks like the Mossberg 500 Rolling Thunder. (same pic and all ) http://www.mossberg.com/images/produ...ISER/55605.jpg
01-07-2010, 06:59 PM #99
Kinda looks like a Winchester 1300 defender with mods.
01-07-2010, 07:15 PM #100
G&A Basics: How to Choose Your First Home Defense Gun
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 02-21-2013, 08:00 AM -
The “Shelf Gun” for Home Defense
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 04-16-2012, 02:20 PM -
Post Your Home Defense
By hutch1999 in forum Gun's & AmmoReplies: 2Last Post: 01-21-2010, 02:37 PM -
home defense system
By ss~zoso~ss in forum Multimedia SectionReplies: 0Last Post: 04-24-2007, 04:47 AM -
Home Defense Handguns
By Moyso in forum Political / Debate ForumReplies: 127Last Post: 02-05-2006, 02:25 PM
