Results 81 to 88 of 88
Thread: 96 turbo civic vs 02 z28
12-15-2009, 11:00 AM #81
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Or ricers cheat
12-15-2009, 01:34 PM #82
Why do you need to call people idiots??
He didn't personally bash you, he was just making fun of that shitty civic, which apparently you took way too personally as always. Get a grip.
Only an idiot would claim that car is "daily driven" or even a street car at all. To make enough power to go that fast with that small of an engine you'll be running race gas, changing oil all the time, and constantly fixing broken parts and rebuilding the engine. And what kind of track is going to let you run 10's without a full cage, suit, or safety gear??
I bet the huge cams, solid mounts, horrible turbo lag, and stage 6 clutch are real street friendly too. Seriously, use some common sense
12-15-2009, 04:48 PM #83
12-15-2009, 08:37 PM #84
- Dec 2008
- FL
Really, so when someone makes fun of a car you put work into, calling you a liar, you're not offended?
It is a full street car. Nothing is changed other than the front tires to run it on the street.
The car runs on 93 octane just fine. It is only running 12psi spring off the wastegate. We have run a 16psi spring as well (not at the track yet). It does not need race gas at all. We run 100 octane pump gas for track events. It does not use race gas.
Changing oil all the time...? what do you mean by that? It gets changed around 2500-3000 miles or so depending on how hard it's driven. A fresh oil change is done before track events though.
Breaking parts? This car was put together well over a year ago. The motor still has excellent compression and guess what... he has not broken anything. Only regular maintenance has been done to the car.
Huge cams? This is a bone stock K20 motor. Stock internals, stock cam. The motor is unopened. It just has the turbo kit and a good tune.
Solid mounts? Nope, just hard rubber mounts with inserts. They hold up fine.
Horrible turbo lag? It's not terrible. It's a small trim 35R twin scroll. I think it spools pretty quick compared to some imports I've been in.
Stage 6 clutch? What? It's running a Clutchmaster sprung disk with a heavy duty pressure plate. It is very streetable.
You seem to think this car is a full race car or something. It is only putting out a bit over 400whp. The car weighs a bit over 2000 lbs. Power to weight.
I sorry you have never seen a well put together Honda. This is what happens when you build a car right.
12-16-2009, 12:38 AM #85
Still doesnt answer the question, which tracks let you run 10s without a cage?? Plus that car looks like a huge turd, does a 274hp civic or whatever civic mentioned in the thread run 10s? No.
12-16-2009, 04:20 AM #86
- Dec 2008
- FL
12-18-2009, 05:06 AM #87
12-18-2009, 10:35 PM #88
- Dec 2008
- FL
Malibu and Civic Turbo
By Archaelas in forum Kill StoriesReplies: 23Last Post: 12-16-2009, 06:49 AM -
z28 vs turbo civic
By fastZ in forum Kill StoriesReplies: 14Last Post: 05-25-2008, 07:27 PM -
Turbo'd Civic
By thecorrectformula in forum Kill StoriesReplies: 84Last Post: 10-29-2007, 07:34 PM -
First Turbo Civic kill.
By Crimson Sin in forum Kill StoriesReplies: 6Last Post: 09-20-2007, 10:38 AM -
WS6(dig)....Turbo Civic(roll)
By Stone in forum Kill StoriesReplies: 11Last Post: 03-10-2007, 01:48 PM
