Results 1 to 3 of 3
09-02-2009, 09:33 AM #1
- Jul 2006
- tx
BLACK- 95 FIREBIRD T-A
Rear end swap 98 to 95 bird? ok??
I think i have a rear end from a 98 bird -- I have a 95. I want to do the switch aroo! both have ABS/Trac control, disk. However, I have been rebuiling the 98 rear end, and noticed after I took off the rotor, (which is bigger than the one on the 95) there where thin drum like pads behind the rotor, as well it has disk pads on the caliper. My 95 rear end is not set up this way. I only have the basic disks and rotor. No little drum pads behind the rotor like the 98. Almost seems as it has disk and rotor combo on it? or is this just the ABS system, or trac control?
Will this work or and im in the dust here? As well , I didnt see the car that the 98 bird rear end came off of so I assuming its from a 98 bird? No way to tell, there are no factory paper #'s on the housing to prove, what it really came from? Maybe it from a diffrent year, not sure how to tell, will it bolt up ok?
Any help would be nice , thanks
Backyard mechanic
09-02-2009, 09:58 AM #2
the rears should swap just fine, what you are looking at are the parking/ e-brakes. At some point GM changed from having it being part of the calliper assembly, to being a seperate system.
09-02-2009, 11:07 AM #3
- Jul 2006
- tx
great thanks, Ill give it a run and see what happens.... Id like to make sure the axle's are not bent first, and bearings are ok. Kinda hard when the axles on the ground and not on the car so I can spin it, and test it
Oh-well , thanks again.
Light Up The Rear Bird
By hippiespace in forum Firebird / WS6Replies: 5Last Post: 02-22-2011, 09:24 AM -
Question: Engine swap to camaro from bird??
By flybird in forum Firebird / WS6Replies: 12Last Post: 12-16-2010, 06:06 AM -
Question: rear T/A bird
By Pony_Eater in forum Showcar and DetailingReplies: 2Last Post: 08-25-2008, 12:32 PM -
how to lite up rear bird ?
By homerunhtr21 in forum Appearance SectionReplies: 6Last Post: 02-21-2007, 06:06 PM -
Rear Bird FILL In
By 1 badblack transam 01 in forum Firebird / WS6Replies: 7Last Post: 05-17-2006, 03:39 PM
