Results 1 to 10 of 10
Thread: What's missing here?
06-17-2009, 01:06 PM #1
- Aug 2006
- Baton Rouge, La.
QuickSilverMetallic- 2005 GTO M6
This is right behind the ABS system and it looks like part of the hose is cut and missing. Looks like the vacuum source for the heater control valve. I looked around but couldn't tell if it hooked to anything...
06-17-2009, 01:21 PM #2
- Retired Outlaw Sum Bitch
Yup...my hose goes through the firewall so I suspect the vent "doohickey"....
06-17-2009, 01:29 PM #3
Hey buddy, It is to the heater control valve. Follow your heater hoses up behind the rear passenger head and it is the botton connection on the right hand side hope this will help you out.
06-17-2009, 01:31 PM #4
- Aug 2006
- Baton Rouge, La.
I'm going to check it out as soon as I get off work. Thanks for the help guys.
06-17-2009, 01:38 PM #5
No problen , just looked under my hood and was too easy. It was all in the open and no problem to trace, sometimes it's easy.
06-17-2009, 04:16 PM #6
- Jan 2009
- North Jersey
Folks are already hackin sheis up on these cars eh? Damn shame.
06-18-2009, 06:41 AM #7
06-18-2009, 10:31 AM #8
I use a propane torch not lit and move it around the intake an TB and if the engine smooths out or RPM come up you have found your leak, never had a problem with it firing up and it is clean no spraying crap all over the place. Try moving the valve by hand it might be stuck, if not it might be messed up or they cut it because the heater core is leaking. Also if you bought it used the ruff running may be a different cam, we already shake a bit because our cam is the same one out of the 05 Vet, I think, good luck and let us know.
06-18-2009, 12:46 PM #9
- Aug 2006
- Baton Rouge, La.
I'll have to get a torch and try it. I found water (very little) in the passenger side front floorboard after I got back from vacation a few weeks ago. Thought maybe it was water from a heavy rain we had. I haven't noticed it running any hotter or losing coolant. The wife drove the car and she thought maybe she didn't shut the door all the way. If it is the heater core how hard are they to change in the GTO's?
06-18-2009, 12:59 PM #10
Sorry man, Have not had that problem [ knock on wood] don't know, maybe someone will chime in and let you know if that is the problem, but that would be where it would leak.
need help??? ls1 missing
By ozmossis in forum LT1Replies: 1Last Post: 11-08-2010, 07:58 PM -
Missing Cat
By SteveCZ28 in forum Almost Anything GoesReplies: 7Last Post: 09-02-2010, 02:18 AM -
Missing ?
By 97txaggie in forum General HelpReplies: 10Last Post: 06-18-2010, 05:36 PM -
Missing Something?????
By predator506 in forum Camaro / SSReplies: 18Last Post: 11-07-2007, 02:10 PM -
What am I missing?
By slims00ls1z28 in forum Request and FeedbackReplies: 1Last Post: 07-01-2007, 11:04 AM
