Results 61 to 69 of 69
Thread: Fuel Pump V-6
05-17-2009, 04:18 PM #61
05-19-2009, 11:34 AM #62
05-19-2009, 11:53 AM #63
You smell that? Smells like gas! Oh damn' you forgot to close the new fuel pump door! Quick open the windows!
05-20-2009, 05:02 AM #64
05-20-2009, 12:29 PM #65
you forgot to add to your list the faulty walbro pump(they recalled) and the need for a better fuel line in california because the gas here eats regular fuel lines....so my 3 times in there were alot better with a hatch....btw if i were your customer i would want the choice so as to reduce cost not for it to be at your discretion
05-20-2009, 01:03 PM #66
05-20-2009, 06:21 PM #67
- Aug 2007
- S. Florida
Black- 1990 Firebird
Cut the exhaust and put a slip coupler on it if you don't have a welder. I have also been able to drop the hangers and make it, but you have to be a contortionist sometimes to do that. While yes I do live in FL, you have to remember that most of the people living here are from up north, very few born/raised here, and they bring their cars with them. While yes, I was able to remove my y-pipe bolts without snapping them, no such luck on the '94 Camaro I'm working on from VA
Man, sounds like you got dealt a bad hand
I don't even tell them that is an option. It's not going to take that much longer to pull the tank vs cutting up the car, working through a little tiny hole, making new fuel connections etc, and sealing it properly. Sure if there was a hole already there, I'd use it and charge accordingly.
To each his own, just not something we do at my shop.
05-20-2009, 09:41 PM #68
05-21-2009, 03:18 PM #69
good idea my Dad did that like 9 years ago
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2011, 09:20 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM
