Results 41 to 60 of 97
Thread: STI Wrx
04-22-2009, 10:05 AM #41
Thats 110WHP over the stock numbers. I don't believe it, period. It takes more than just bolt ons to gain that kind of power, and you know it.
Not to mention STI engines aren't forged. Meaning cranking up the boost and making significantly more power than stock is nothing more than a recipe for disaster. Most often its the rods and rod bearings that give out on them first. I've personally seen 3 STI engines meet their fate that way.
And there are plenty of bolt on LS1's running low 12's and high 11's. It takes nothing more than full bolt ons and a set of DR's or slicks.
04-22-2009, 11:10 AM #42
- Mar 2009
- Milwaukee
Arctic White, red/gray- 1997 Corvette, 92 Typhoon
Id like to see any full weight, bolt on ls1 with just drag radials run 11s. That mean no drive train work.
BTW people with agressive pump gas tunes have gotten 300whp on the evo x with no other mods than tuning. Vishnu even though his tunes are known to be less reliable than other has gotten 310whp out of a stock evo x with just a tune. The bolt on parts arent even what gives big hp bumps on these turbo cars, its the ability to spool faster and harder that opens the door for more tuning which is what yields results.
HB speed which is a good race team in time attack competitions has dynoed near 340whp on there dyno on stock turbo evo xs.
04-22-2009, 11:24 AM #43
04-22-2009, 11:29 AM #44
Look around. I'm not going to waste my time on you proving something about LS1 cars on an LS1 forum.
Its called "cranking up the boost". Interesting how you leave that part of the "tune" out
haha are they really that bad?
04-22-2009, 11:36 AM #45
- Mar 2009
- Milwaukee
Yes the boost does change, but you also leave out that so does everything else to make the tune a reliable one. I went from 12psi(190whp) to 17psi(250whp) and i spool 500rpms quicker almost 40kmiles ago on my legacy gt and i have never had one problem with the car, its my dd. Some guys with manual trannys are putting down 280whp on bolt on legacy gts which have far subpar turbos compared to the sti.
04-22-2009, 11:56 AM #46
- Feb 2008
- Chicago
Tarmac Black- 05 Evo VIII
ignore wesman... He works on these cars.. but yet doesn't know what their capable of. You have multiple people on here who own LS1 F-bodies, and other "tuner" cars as a DD, but when they say what they can do, you don't want to hear it.
Don't be upset that a stock 4 banger can out perform a stock LS1 in the quarter.. I'll keep my, as you say "clutch frying launches" and you can keep your glass rear end..All stock Evo VIII 12.95 @ 106.32mph with a 1.89 60ft.
Highest stock trap: 107.26mph
04-22-2009, 11:58 AM #47
04-22-2009, 12:42 PM #48
- Mar 2009
- Shepherdsville, KY
Onyx Black, M6- 2001 SS Convertible #4498
just for the record my 05 STi (smaller turbo) with nothing but intake and 3" turbo back exhaust dynoed 290awhp on a VERY reliable local dyno, and this was WITHOUT A TUNE....the new ones should be able to do that EASILY.
04-22-2009, 12:49 PM #49
04-22-2009, 01:14 PM #50
- Mar 2009
- Milwaukee
I would say thats not a mustang dyno, on a mustang dyno your car would put down 260-270whp but with a tune 300-320whp would be what you would have seen on a msutang dyno and 330-350whp on a dyno jet. Stock STI turbos can spool 22psi and be reliable on 93 octane and no water/meth system.
04-22-2009, 01:42 PM #51
04-22-2009, 01:46 PM #52
- Dec 2008
- FL
04-22-2009, 01:47 PM #53
- Mar 2009
- Milwaukee
Like i said he must not have been on a mustang dyno. Evox/new STI put down 240-250whp on a mustang dyno and 270-280whp on a dyno jet. And or yes the boost was turned up because intakes dont really do anything on STI/LGT engine at these power levels without being tuned in.
04-22-2009, 08:18 PM #54
04-23-2009, 06:55 AM #55
- Mar 2009
- Milwaukee
They dont fall flat at higher mph, they trap what any 240whp car would. The just have such fast 1/4miles times because of the launch. If a STI put down 300whp and a ls1 car put down 300whp there traps speeds would be almost the same since they are both 3400ishlbs cars with 300whp but the STI would have a faster 1/4miles time because it can launch so well.
Its a common mistake people make thinking that evos and STIs have horrible top end, they have the same top end any turbo car with 240whp would have. AWD doesnt hurt you from going fast it just takes more hp from the crank to the wheels, but wheel hp is wheel hp and if a evo or sti is making 300whp it will hang with a 300whp ls1 car even on a roll.Last edited by Zinergy; 04-23-2009 at 06:58 AM.
04-23-2009, 08:40 AM #56
Common mistake?? Not really.
Everyone views the Evo and STI as low 13 second cars. And when you launch like you stole it, they can be. So ricers think that because they can run low 13's, they are as fast as other cars that run low 13's. Then they get annihalated from anthing other than a dig by a stock LS1 or a Mustang Cobra, and its like a huge reality check. Evos and STI's aren't fast cars. They are quick cars, which means they can go from point A to point B in a hurry, but they aren't powerful. They also have no top end because the fall off boost at high RPM's, so they don't any good top end power, either. Like I've said, you feel the acceleration in 1st through 3rd, after that you might as well get out and push.
04-23-2009, 08:43 AM #57
- Mar 2009
You guys crack me up....it was STOCK BOOST, no boost controller, NO TUNE. 290AWHP. Period. You guys just don't want to admit that these cars can make some really good power VERY easily...
I probably have the graph around here somewhere, maybe I'll post it. Doubt all you want.
04-23-2009, 08:44 AM #58
- Mar 2009
04-23-2009, 08:52 AM #59
- Mar 2009
- Milwaukee
They trap what any 240whp car would like i said, there are soo many way to keep the boost at peak boost all the way to redline. It tappers off in stock form but a modded sti or evo can easily keep it up. I totally agree that a stock ls1 car vs a stock sti or evo from a roll the ls1 would blow it away. But that doesnt mean it would happen the same way if both were bolt on cars putting out 330-340whp each. It would be a close race even from a roll.
04-23-2009, 08:58 AM #60
- Mar 2009
- Milwaukee
You may have very well put down 290whp on a dyno in a 05 sti with a CAI and CBE. But that doesnt mean its a real number, that dyno was NOT a mustang dyno and on dyno jets like i said EVOs and STIs put down 260-270whp. But they are many thing a tuner cna change on a dyno to make the numbers seem higher. First off a cat back exhaust and cold air intake on the ej25 engine does almost nothing unless your tuned for it, i know this because i have tuned many subies including my own legacy gt. I wish you had some dyno charts from when you were stock, because most 2.5 turbo subies will gain 10whp from the mods you had and no tuning. Which would mean you would make 280whp stock which is way high.
Im not some import hater, i have a supra, a honda crotch rocket and a subaru legacy gt(same long block as your 05 STI) that i own. So i know what the sti engine can and cant do, and buddy it cant make 290whp with a CAI and CBE unless tuned and or the dyno was adjusted to inflate numbersLast edited by Zinergy; 04-23-2009 at 09:01 AM.
