Results 41 to 47 of 47
Thread: ??? LS1 Heads vs LS6 Heads ???
03-04-2009, 11:45 AM #41
- Jan 2006
- Shepherd, Michigan
243 heads are the same casting..nothing really changed...243 from 01 on down will NOT have the lightweight valves..02+ 243 besides ones found on the ls2 will have the lightweight vlaves and "higher lift springs" i believe they accept 500 lift...but besides that there is no difference in the 243..the 243s however are produced at several plants of which two(i believe) had a special casting process that allowed for VERY tight tolerances ..these are marked with the triangle ..but besides that nothing didnt on the castings..i personally will pick up some off a ls2..and get them worked ...since new springs and valves are in my plans anyways
03-04-2009, 01:59 PM #42
I can't find any definitive information on the combustion chambers but either the pistons or the combustion chambers would have to be different on the LS2 cast 243 heads otherwise the compression would be 11:1 or more. And I do know these motors didn't have that much compression from the factory.....So where was the change made???? In the head or the piston??? I know on the 6.0 truck motors the change was made in the heads,,,to 71cc combustion chambers,,yet they also had the same port dimensions and D-shape exhaust port as the LS6's.
Like I said, I wish I had a set of these later model 243's in my hand, I would love to poor the chambers and see where they are.
As far as the castings and the triangular marks, that goes for all heads, I have a set of 241's like that as well.
03-06-2009, 08:18 AM #43
03-28-2009, 08:37 AM #44
- Oct 2007
- Macomb, Michigan
Black on Black- 2001 ~ T/A ~ WS6 ~ M6
I'm looking at head gaskets and standard (stock) thickness is .051".
I found these http://www.trickflow.com/partdetail....&autoview= sku they're .045" thick compressed instead of .051". They'll bump the compression up a bit and I wouldn't think there would be any issues going only .006" thiner (e.g. intake fit, etc).
$72 each at Summit. If I want to go cheaper ($$$ wise) everything is .051" thick and up. I wonder how much of a difference in compression .006" will make? Might not be worth the extra cash.
Anybody, anybody, anybody?
03-28-2009, 08:17 PM #45
Well it wouldn't make a ton of difference in compression but there are other advantages that are worthwhile.
What it does do is increases the "quench" area or I should say makes the quench tighter. That's the flat area of the head that is inside the bore and covers about half the piston top.
A tight quench is good for promoting swirl in the chamber which is a good thing. This helps prevent detonation (even at a slight increase in compression) and although it hasn't been shown to provide a power increase, it does promote and more complete burn and most engine builders strive for a tighter quench area.
It's actually been shown that running a thicker head gasket and dropping the compression can actually cause a detonation problem because the quench area has been increased to a point of diminishing returns.
03-29-2009, 03:57 AM #46
10-15-2014, 09:11 PM #47
- Oct 2014
- United States
I've got the same combo but having a little trouble picking the correct head gaskets any one know what the head bore on the gaskets should be 4.8 ls1 with 6.0 heads
Late-Model GTO Heads and Cam - The Voice Inside Our Heads, P
By Ed Blown Vert in forum GTOReplies: 0Last Post: 03-16-2011, 09:30 AM -
By Ed Blown Vert in forum GTOReplies: 0Last Post: 02-04-2011, 02:00 PM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
New Heads or Port/Polish Stock Heads?
By Black02LS1 in forum Internal EngineReplies: 32Last Post: 06-22-2007, 11:29 PM
