04-14-2018, 09:18 AM #1
Need New Valve Springs. Suggestions?
My valve springs are at the limit of their serviceable mileage.
I have some machined heads and mild cam (360 whp) with room to grow to about 400-450 whp. I'm still running stock intake/exhaust, but may change these out eventually.
I've done some cursory searching through various options, but not sure how to differentiate what's available.
I run Amsoil Z-Rod exclusively in the engine, in case that matters.
04-14-2018, 11:31 AM #2
Brian Tooley Racing......
00 FB Vert - Stock
04-15-2018, 03:33 AM #3
i'll be using vinci high performance SS SK dual springs for my upcoming maintenance swap
LS1
HIGH TENSILE CHROME - SILICON STEEL - HIGH LUSTER FINISH
INCLUDES SUPER LIGHTWEIGHT TOOL STEEL RETAINERS, SPRING LOCATORS ,VITON SEALS , HARDENED LOCKS
SPECIALLY DESIGNED FOR STREET / STRIP LSX APPLICATIONS
DROP-IN KIT, NO MACHINE WORK
SPECS:
155 lbs @ 1.780"
360 lbs @ 1.230"
380 lbs @ 1.180"
400 lbs @ 1.130 "
coil bind @ 1.070"
od; 1.300
will handle .660" lift with ample coil clearance
04-15-2018, 05:43 AM #4
Ah, yes... Silicon Steel... I just learned about that researching magazine springs. It seems like a no brainer in a valve spring application.
Vinci's website says the dual springs will not fit iron heads... Not sure whether mine are iron (but I think they are).
Scott, thanks for the reference.
Now I have a bunch of homework to do.Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
04-15-2018, 10:30 AM #5
Iron heads come on truck motors like 6.0. 5.7 are aluminum. If you want to make sure, put a magnet to the heads.
04-16-2018, 04:58 AM #6
Oops. I thought that the LS1 had aluminum block and iron heads, while the truck motors had iron top and bottom.
04-16-2018, 07:54 AM #7
GM got away from iron heads when they went to GEN III LS.
04-18-2018, 02:59 AM #8
pictures of the vinci springs i am installing this weekend.
http://www.ls1.com/forums/f117/sprin...lation-187607/
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 08:14 PM -
valve train and head suggestions
By Larry Woodfin in forum Internal EngineReplies: 0Last Post: 03-27-2009, 06:21 PM -
valve springs,HAL struts and springs,grannatelli lid
By nosty1 in forum Parts For Sale / TradeReplies: 2Last Post: 07-25-2007, 05:23 PM -
struts/springs,lid,ls6 valve springs,F-body fuel pump hotwire kit
By nosty1 in forum Parts For Sale / TradeReplies: 9Last Post: 06-30-2007, 03:33 AM -
Fs: New Ls6 Valve Springs
By 96lt1z28 in forum Parts For Sale / TradeReplies: 2Last Post: 01-22-2007, 10:03 AM
