Results 1 to 20 of 21
    tire pressures at the track...
    Going to the track tomorrow and wanted to see where you guys usually run on tire pressures. Only supposed to get up to 60-65 tomorrow. I'll be running Nitto's.
    Junior Member TwiSSter418's Avatar
    Florida mostly
    my 315/35/17 nittos worked best for me at 17-18psi. that was a full weight car with a torque arm and control arms. (maybe gears, i forget!)
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I would start at 22 and work down from there! Get a real guage also or your pissing in the wind.
    Bragg NC
    Met. Sunset Orange
    01 SS
    I ran the nitto's with no luck, Almost bought the wall three times, now they sit in my shed with no track time insight.
    I ran them at 20, 18, 14 Psi and like said above make sure ya take a good guage with ya.
    J
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yeah they only work on light power applications! I would buy Mickeys or M&H's. The M&H's work better but at the same acspect wear quicker.
    Florida mostly
    once I got real drag suspension, it started to overload the tires and it would just start to hop. overall it was a mess. if you plan on getting some real suspension or have a lot of power i'd get some real 15"s and call it a day.. I love mine.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by TwiSSter418 View Post
    Anymore 15's are NOT a must with the tires we have now. I'm doing 1.5 60 foots on a 275/40/17 drag radial and blowing off low 11.20's pedaling the car to save stock rear-ends.
    I just don't like doing all that grinding on the calipers unless I have a low 10 second car.
    I ended up at 15 psi. Had bad traction problems all day. Even rolling off the line I was getting some wheel spin and averaging 1.9-2.0 60' times. I feel those 60's should've been much better with drag radials and a stall. Granted, most of it is probably operator error because I don't have much experience at the track.
    Florida mostly
    hey, I was just saying what I did and did not have luck with on my car.. once I got QA1s etc etc the 17s just couldn't handle it. and if you run convo pros you don't have to grind anything...
    Member rel3rd's Avatar
    Baltimore, MD.
    Bright Red
    2000 Pontiac Trans Am WS6
    I went last night and tried my 275/40/17 Nittos (and car) out for the first time. I wanted to make 2 passes exactly as I drive it and then let some air out. Two runs at 32psi, then two runs at 20psi. Car had zero wheelspin launching from 1300rpm's with a 3600 PI Vig converter. Three 1.77's and a hot lapped 1.79 was what I wound up with.
    2019 Silverado LT Z71 5.3, 8L90E
    2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
    9.32@147
    Member william SS's Avatar
    Tulsa, OK
    2001 camaro SS
    Would it make a difference if I lowerd my tire pressure? Every one says to but im not sure. Im running nitto 555R drag radials 275/40/17 at 42 or 43 psi. I had them put on brand new about 3 months ago. In my ss I have 3200 stall and 389 gears. I usually rev it up to 25 or 2600 rpm when leaving the line and cutting a 60' of 1.84. i seem to hook up every time. I might spin the tires 1 out of every 5 runs I make. But I really never feel it spin. I remeber once lowering my tire pressure b4 i did my mods and i spun spun spun. B4 I had lowered them i wasnt spining. So what do you guys think? Should I try lowering the pressure or keep it at what its at and am I launching at the right rpm?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes I would! The tire can not work properly at that high of pressure. You should be able to launch the more aggressively if it's hooking now with that high pressure.
    Personally I would start at 22psi and play with it from there.
    Every car reacts different so if someone jump out and tells you what rpm to launch at....... Yeah right..... It is trial and error.
    As far as your suspension the stock SS springs and shocks are designed for handling NOT drag racing! If you still have the stock rock hard rear springs I would suggest replacing them with a pair of junkyard V-6 springs. It will make a huge difference especially on the street.
    Galloway, NJ
    Light Pewter Metallic
    1999 Camaro SS
    ive got a set of Mickey Thomson drag radials, and usually lower the pressure to 14, 15, or 16, and ive tried launching at 1500-4000k rpms, and last time i launched at 4000 jus experimenting it finally hooked an got a 1.8 60', and launching at the lower rpms would jus make the car bog out and give me a 2.0-2.2 60' which is horrible, so i still have to get the launch down, but i jus started racin with drags this year. like it was said above, every car is different. jus have to really try different pressures an see how it works. jus remember if your tires are hot and you lower the pressure, its going to change slightly when they cool if ure stuck in the staging lanes forever, and same thing goes after u do the burnout. simple physics, but it shouldnt affect your run that much, least i dont think.
    1999 Camaro SS coupe #1355 1 out of 74.
    Mods: SLP cold air induction, SLP LT's, high flow cats, y-pipe, SLP loudmouth exhaust, Moser 12bolt rear, Detriot Truetrac, 3.73's, BMR lower control arms, BMR adj. torque arm, Hurst billet shifter w/ knob, MSD spark plug wires, Mickey Thomson drag radials.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by 1LoudSS View Post
    They are 16" or 17" you are running????
    d
    2002 z28
    i didnt lower my rear tire pressure today at track since it was a cheap ass track with no air compreesor, and ran 1.9 60' time and 13.2ish on motor with 35 psi on all tires.
    how would my run differ with dropeed psi??
    what is prefered street tires psi.. bfg g force ???
    front and rears????
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    On the 17" BFG's I usually have the best luck at 24-26.
    Don't drive through the water!!! Drive around it back up stoping BEFORE the water and just clean the tires off. NO SMOKEY BURNOUT!!
    And on the fronts I usually inflate to max pressure unless I'm runnuing front runners (15x3.5") to make as skinny of tread contact as possiable.
    You can go to a nice concrete parking lot and figure out exactly what pressure will give you the best contact pacth on the rears. Just do light burnouts looking at the marks varying pressure by 2 lbs at a time until the mark is uniform as in even across the tire.
    d
    2002 z28
    Quote Originally Posted by LS2Tuner View Post
    thanks and , but you said no smokey burn out. like i see our cars( fbodys/stangs) doing 15 ' tall burn outs while some 8 sec cars are just lighting up a lil , with barley any smoke.
    and is it better to do a burn out holding like mid 2000 rpm or go like 5000, ? which one is safer? /efficaent
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by greatwhiteZ28 View Post
    Just in short term answer. You never want to buzz or rev a motor high in the water box.....Thats why soooo many people blow there shit up doing a burnout. You want to up shift as soon as you can efficiently to increase tire speed. Unless your breaking into the 1.2-1.4 60' times there is NO need to do a John Force.
    On any mid to high 11 second car you should NOT need anymore than a slight cloud and rolling into the beams.
    d
    2002 z28
    thanks, but i just leave in OD, i dont shift my auto, seen lots do it before on tv. but never tryed it.
    Member Lawnman's Avatar
    Aug 2006
    lookin for a ws6
    re
    What track ?
    I am going to NTR east of Columbus tomorrow , I would like to see as many f-bodies as possible.
  1. Replies: 2
    Last Post: 04-30-2014, 05:20 PM
  2. Track Day Prep Guide - Open Track Packin'
    Last Post: 09-01-2010, 03:00 PM
  3. Replies: 1
    Last Post: 03-22-2007, 12:26 PM
  4. Tire choices for the track
    By Havoc_S in forum Wheels and Tires
    Last Post: 11-08-2005, 03:36 PM
