Results 1 to 20 of 36
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    Freaking Slp Lid Doesn't Lock!!!!
    I bought an SLP lid for my trans am and one of the latches doesn't close? Have any of you had this same problem? How or what can i do to keep the damn thing closed?
    Harrisburg
    2000 TA
    i thought the same thing when i first got mine but then i played with it alittle more and got it to fit nice and snug. Is the lip on the front on the inside or outside of the bottom mount. I ended up making mine work on the inside.
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    Quote Originally Posted by texinteg View Post
    No i think that the slp lid the upper is over the bottom part. That's how i have it on right now. The right latch closes fine, it's the left one that always keeps on opening up!
    if you got any pics it would help alot man! thanks!
    1 01ls1ws6's Avatar
    houston tx
    pewter
    01 ws6
    yep
    Harrisburg
    2000 TA
    Dont have any pics but mine definately fit better when I tucked the upper front into the lower bottom.
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    mine fit funny at first. I also had to just play with it. One issue was my Fernco coupler, it wasnt allowing it to sit all the way down, i just had to loosen it and twist the lid some to fix snug.
    Member sirenformula350's Avatar
    Chicago
    I had the same problem for the longest time and like everyone else said make sure the front part of the lid is sitting behind the lip of the box. If you really need a pic I might be able to get one up at the end of the weekend. Unless anyone else beats me to it.
    Bmike Dillard99's Avatar
    Charlotte,NorthCarolina
    Metalic Navy Blue
    2001 Camaro Z28
    yep mine is to the right side locks up but the left side keeps poping off
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by SMOKIN WS6 View Post
    You answered your own question...the lids lip goes inside of the lower air assemblys lip.
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    I had the same problem, I ended up screwing around with the smooth bellows so the lid could slide back a little bit.
    Member waldo's Avatar
    Wisconsin
    Machine Silver
    05 Corvette
    Quote Originally Posted by GottaHaveLS1 View Post
    Had the same problem. Just be patient and keep adjusting and reclosing it, it will settle in and stay closed…… eventually.
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    My Dr side always kept coming unlatched... till I said fuck the K&N (cleaned it 3 times in less than 2 months.. and went back to the paper filter.. and it sealed nice and tight and no probs since.
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    same thing here,mine was a little hard to get on but thats what you want to get a snug fit. Ill take a pick and post it
    navy blue metallic
    2001 trans am
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Lid is supposed to be TOP INSIDE LOWER LIP on all lids no matter who made them.
    Shove that sucker all the way back & it'll stay latched.....that is all
    navy blue metallic
    2001 trans am
    my core support is tweeked from a mild front end collison so my lid doesnt fit PERFECT bit its tight ans sealed good due to the filter being in there
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    I have the exact same problem... i fell for the smooth bellows crap so now i have less flexibility to play around with the lid since it's way tougher than the accordion style one. i guess i just gotta play around with it some more!
    so the top part of my lid goes inside not outside to fit better right?
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    I HATE THIS LID IT JUST WON'T STAY CLOSED!!!!
    Indianapolis, IN
    All Black
    You could always get some rubber weatherstripping from like Lowes or something to put under the lid.. so It seals tighter.. making the clip stay latched... thats what I was going to do if the paper filter didn't make it fit right.
    EL PASO TX.
    NAVY BLUE METALLIC
    02' WS6 TRANS AM
    I think it closes fine.... it's just that the stupid clip seems like it's not long enought to latch on to the lid. Guess i just need to play with it some more!
  1. Power door lock doesn't work on drivers door..
    By 99RedTa6spd in forum Firebird / WS6
    Last Post: 09-03-2014, 08:20 AM
  2. tranny,lock up/no lock up.................
    By NEXSTAR7 in forum Automatic Transmission
    Last Post: 10-07-2009, 12:17 PM
  3. freaking out!
    By Raoul-Duke in forum GTO
    Last Post: 04-04-2008, 04:24 PM
  4. stall question.. LOCK UP or no lock up whats the difference?
    By greatwhiteZ28 in forum Automatic Transmission
    Last Post: 04-05-2007, 04:01 PM
  5. Remote lock system freaking out
    By Ram98 in forum Firebird / WS6
    Last Post: 09-04-2006, 10:38 AM
