Results 1 to 20 of 25
Thread: Fuel Pump Mods
    Retired Outlaw Sum Bitch
    Fuel Pump Mods
    Without wandering into the various methodologies and "fixes"....thought I'd share some of my experiance and conclusions.
    Firstly the stock fuel setup is gonna crap the bed around 400RWHP....H/C w Nitrous LS1 I had saw a 20lb drop at WOT w/100shot...from 60-40lbs....
    I have a FP guage next to the AEM A/F guage so I watch them....
    I read all the discussions till my eyeballs fell out.....and when we dropped the 402 in knew we had to do "something" prior to the ProCharger....so we did the bucket mod and Walbro 255...but there is more....after the bucket mod w/new pump we still saw a drop in FP of about 15-20lbs.....so back out came the tank.....the bucket sits flush on the bottom of the tank....we had drilled the holes in the bottom like I had read.....wrong....we drilled additional holes in the side....now we had fuel in the bucket....
    Look at this kinked up rinky ass dinky fuel line coming out of the tank from the factory.......think mebbe this could be a restriction?
    I did...we replaced it with a more suitable solution....
    Put the tank back in....voila! 62lbs FP presure throughout the RPM range....rock solid....now the hog injectors and fuel rails get all they want and the FP doesn't flinch.....there now it works....
    So replace that POS hose...drill the holes in the side of the bucket....and for a couple of hundred bucks for the pump and the hose....you got the fuel pressure issue solved....
    Western Maryland LS1's
    Maryland
    1999 Camaro SS
    Awesome tip Sarge!
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    did the drop in pressure cause detonation at WOT?
    doesn'tplaywellwithothers superchargedblackgto's Avatar
    Mayberry....(Indiana)
    2004 GTO
    I did this same mod...running 10psi of boost, I see a drop in pressure, this is a good fix for N/A, and boost 10 and less, or about 480rwhp and that is pushing it. however if you go more, you will need to put in 2 pumps, external regulator, and upgrade the fuel system......But it works great for above application...remember guys F/I cars require more fuel than N/A..
    Great tip Sarge
    Brad
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    i've been having fuel problems with my bolt on 99 T/A. i've replaced the pump and fuel filter. My lines are slightly kinked so maybe i should replace them. Could screwing the holes out the side help me too?? sorry about bringing back such an old thread
    Well flow is critical to maintaining fuel pressure...you have restrictions in the fuel bucket yes it is an issue for sure....the "drill mod" definetly works....just don't let the fuel level get below like a 1/8 of tank....
    Connecticut
    1999 Trans Am M6
    but i've had the same bucket in there since i bought the car over three years ago. Is it an issue now just cuz of my new walbro 255 pump? I wonder if it will fix my problem entirely. So does the car just die when i go below that mark?
    What happens is the new pump will pump the gas out of the bucket quicker than the fuel can flow back in it....so your good for say a 10-15 seconds WOT run then you go instantly lean/kaboom.....or run the very high risk of it....
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i know when i go for a new pump etc..i will do the drill mod and change that hose... so i can be ready when the time comes
    Connecticut
    1999 Trans Am M6
    it looks like i'll have to do this mod then.
    I see the same thread in the General...the FBody guys and us have slightly different setups guys.....
    rednari
    Guest
    It is a good write up. I remember when he first posted it. I would add though, from experience learned since Sarge first experimented with bucket upgrades, it is better practice to drill the extra holes in the bottom and not the sides. This way when the tank in below 1/4, and you are corning hard, the motor is less likely to fuel starve.
    Originally, I drilled holes in the side too. But later had to go back in and wire some gas tank foam over the holes to stop backflow. I do not know for sure if bottom drilling the holes is a cure all, but I suspect it would help.
    Anyway, the holes plus the Waldbro 255 pump will give you enough fuel for almost any type of motor. There are people who have spent many hours and dollars upgrading to the 8 liter fuel module (Silverado module) because it has two inlets, when all you need are two extra holes in the bottom and/or fuel tank foam to stop starvation.
    LOL...yeah I followed some of the more complex fuel system "upgrades" for our GTO's on another forum for awhile. Unreal! I keep 62lbs of FP at the rails even at WOT....cannot imagine any motor needing more than this bucket mod.
    rednari
    Guest
    Agreed! 62#s at WOT on a 408 stroker is enough fuel for any street car.
    Nov 2008
    Dallas
    Blue
    2005 GTO
    In need of the fuel line from tank Both the clips broken Any idea (hose was kinked also)
    Pontiac has to order from down under Got a love it
    Drilling holes as I type APS system air ratio dropping to 10 to 1 above 5 grand and fuel pressure drop
    Thanks for any info
    Shagman
    hitchcock, texas
    1978 280z- ls1-v8
    ls1 swap
    Hey Sarge.
    I am putting a ls1 in a datsun 280z with about 520 hp,trick flow heads 11.1 comp. , 232/236 .585 lsa 112, fast 92mm intake and throttle body and custom headers. Will be using a RCI 16 gallon fuel cell. Would like to put the pump in the tank to keep it away from the heat. What do you recomend for a fuel system and what size headers(custom made)?
    Mark
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    I have to totally disagree on one item. It is NOT a good idea to drill holes in the bottom. With a low amount of fuel in the tank, as the gas sloshes around, the bucket will empty out of these hole and you will starve. I have seen several top performance shops say don't do this. LPE is one. The guys that tune my car is another.
    Quote Originally Posted by scubamark3995 View Post
    Hey Sarge.
    Mark
    Walbro 255......more than enough...I assume your going returnless?
    1 7/8" on the headers with those numbers/heads/compression ratio.
    Quote Originally Posted by GTO1_OHIO View Post
    Yeah and dont sit too close to the TV cuz you'll go blind. Totally overblown internet bullshit. I have ran mine down to damn near nothing with no issues at all many times. I am forgetful....but I do try and not let it go below a 1/4 tank....run em at the track at 3/8 full and your golden....and knock that shit off in the shower...you'll grow hair on your palms.
    hitchcock, texas
    1978 280z- ls1-v8
    Sarge. Thanks for the feed back. Should I try for long or mid lenght headers?
  1. Fuel pump fuel guage issues on my '02 B4C
    By ANDYZ28 in forum Camaro / SS
    Last Post: 12-29-2014, 10:30 AM
  2. Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
    Last Post: 03-15-2011, 09:20 PM
  3. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  4. Replies: 3
    Last Post: 10-02-2006, 06:23 PM
  5. Fuel Pump Pump Problem?????? Help!
    By undertakersT/A in forum General Help
    Last Post: 04-24-2006, 09:55 AM
