Results 1 to 20 of 33
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Is this normal for a new clutch
    About a week ago I installed a new brand new Spec stage 1 clutch.
    Everything was fine double checked (clutch, pressure plate, flywheel) and install was correct.
    The car drives fine and it catches good.
    But my car does have a chatter now. Its only when I am taking off and the whole car should shake. It does it only sometimes other times it leaves just fine. I was expecting a slight chatter for new clutches but I didn't think it was cause the whole car to shake.
    Also my clutch pedal even at idle vibrates, I do not recall it doing it before the install either.
    Are these normal symptoms are do I have a problem?
    Also the other day my friend got in the car (he normally drives a 240SX) and pinpointed that my car if its in 1st gear and he just slowly releases the clutch without any gas the car does move forward. It has always been able to do that even before the new clutch. Is that normal too? I never really do it but I am just wondering.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Talking
    Quote Originally Posted by JwMonE99 View Post
    Aaaahhh yeah...release the clutch and the car will move.
    Was your flywheel resurfaced? Is pedal engagement/freeplay all where it should be? I did a clutch in my Ranger last summer and for the first 2-3 weeks it had occasional chatter exactly like you described. Since then, it has been fine. Like brakes, it probably has to go through a few heat cycles to settle in. Just be kind to it for a bit.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Yes flywheel was resurfaced.
    yes free play and engagement is about where fine.
    So that chatter you got shook the whole car?
    Good makes me feel better.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Well he told me that his car would just stall out.
    Not dramatically -- but yes, the whole truck would shudder when it happened.
    Madison, WI
    2001 Silverado Z71
    his nissan has no balls. your LS1 has lots more torque. More power makes it harder to stall the engine.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Ok I gotcha. Thank you
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Just wondering if anyone else had the same symptoms from a new clutch that pajeff02 and I had?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Exactly what I was going to say. A Nissan 240 is a gutless 4 banger. If yo don't rev the piss out of the engine before releasing the clutch, it will stall out.
    In an LS1 car, if you release the clutch to the grab point at idle, the car will start to take off.
    Senior Member karpetcm's Avatar
    Tujunga, CA
    01 Camaro 6speed
    I had this kind of problem on 3 of the past camaro's and the car would shake bad, major chatter. It held up and was able to drive it for a while before replacing it. Ofcourse having to much chatter like i did was not good but mine was a stage 3 clutch and after a while i just accepted it even though it shouldnt have been chattering as much as it did. The key is how you do the install which seems youve double checked everything but also how well you break it in. Otherwise my own experience aftermarket clutches will chatter there are some cases for a few people that it doesnt.
    Jun 2009
    Brisbane
    2004 VZ SS Commodore
    Hi,
    I am new just joined to-day,
    Did you clean all oil or grease from your new flywheel and pressure plate, they come with a coating to stop rust when new.
    If not this will cause your clutch to chatter on take off, it will fix its self in time
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Quote Originally Posted by proc1 View Post
    Hi,
    Normally I would do something like this with my friends but I was in desperate need to have it done fast so I took it to a shop. The first time it had chatter and I made them take it apart and check everything and re-install it. They were a reputable shop and was highly reccomended so ima have to assume they did it correctly.
    But lets say they didnt grease the flywheel or clean the oil ect. ect. and the chatter will go away, how long would you think? I have put roughly 300-350 miles on it so far.
    BTW welcome to the site. ; )
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I have read 500 break-in miles for a new clutch set-up. It is probably different from manufacture to manufacture though.
    USA
    BLACK
    Z/28 LS1
    If it doesn't go away after 500 miles -go to a hill and ride the clutch for a few minutes-LOL
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Because you have this
    houston
    Navy Blue
    ls1 trans am
    Well not to rain on your parade but chances are the clutch was installed properly and everything however, SPEC clutches are known to chater like craazy. It is very annoying and people riding in the car ask me whats wrong because yes, it shakes the whole car!! I had a SPEC stage III clutch and was told by the shop that installed that it would only chatter until it got broken in. However, the clutch chattered (on take offs mainly in first gear) for the life of the clutch. thats why i went with a LS7 no chatter! I will say that your case might be slightly different because I had a spec stage III ceramic disc. Not sure the make up of your clutch. just my .02
    Member WARP211's Avatar
    Feb 2007
    FairField, CA
    RED 35TH ANIVERSARY PKG
    2002 CAMARO SS 35th LE
    Also the other day my friend got in the car (he normally drives a 240SX) and pinpointed that my car if its in 1st gear and he just slowly releases the clutch without any gas the car does move forward. It has always been able to do that even before the new clutch. Is that normal too? I never really do it but I am just wondering.[/QUOTE]
    Yeah it's called TORQUE..
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    rev it sky high, dump the clutch = no chatter ... you're welcome ... lol
    Quote Originally Posted by That Guy 2-1 View Post
    No chatter indeed...just a clunk noise from the 10 bolt going bye bye lol.
  1. Question: is this normal?
    By dav-02ws6-m6 in forum General Help
    Last Post: 05-16-2010, 05:53 PM
  2. Is This Normal?
    By bgable in forum General Help
    Last Post: 04-29-2008, 05:37 PM
  3. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  4. LT1 WS6 vs. normal
    By riceslayer302 in forum LT1
    Last Post: 06-24-2007, 12:20 PM
  5. is this normal?
    By TA-LVR in forum Stereo and Electronics
    Last Post: 02-19-2006, 05:09 PM
