Results 1 to 16 of 16
Thread: Bump Stop Mod Question
11-09-2007, 07:34 AM #1
I know if I am doing this I should use a scanner to see what percentage the throttle is open to. But, I don't have a scanner. Can I just eye ball it? Or use a Volt meter. . . . .
11-09-2007, 08:10 AM #2
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
I would not "eyeball it" if you are wrong the damage cannot be undone and it will send the error code.
11-09-2007, 08:50 AM #3
It can be undone by threading it, then re adj. back fwd w a screw. Seen it done.
Actually some just shave it, drill , thread it, then adj w the screw to get it nats ass 89.5 degrees. I wouldn't eye ball it btw.04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
11-09-2007, 09:26 AM #4
mark shaner eyeballs it
11-09-2007, 09:34 AM #5
11-09-2007, 10:12 AM #6
- Oct 2007
- Scott City, Kansas
Black- 98 Ws.6
11-09-2007, 01:14 PM #7
i dunno, when i went to mark's house i asked him about it and he said he never used it, just as long as you dont over do it
11-10-2007, 03:40 AM #8
- Nov 2006
- Earth
Yes, that is how the TPS is checked for position and to determine if the signal remains linear through its travel. This is a 5 volt signal that is modified by resistance. The closer to the maximum travel the lower the resistance. I'm sure you already know the maximum voltage signal for WOT. BTW, mine was correct without the mod.
11-10-2007, 11:40 AM #9
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
YES YOU CAN!!!!
Make sure the volt meter does not go past 4.6 volts. most cars before the bumpstop mod read 3.3 - 3.9.
4.6 volts is right under 90 degrees open. Anything more will set off a SES light
connect the positive end of the voltmeter to the TPS and the negative end to the negative battery terminal for ground.
11-10-2007, 06:45 PM #10
- Oct 2007
Black- 98 Ws.6
I stand corrected lol
11-12-2007, 02:55 PM #11
02-10-2008, 09:35 AM #12
- Oct 2007
- Beaver Dam KY
Any pics on the idea of an adjuster screw for the bump stop>?
02-11-2008, 06:08 PM #13
Drill a hole in the bump stop, thread it and put a screw towards the plate that opens the butterfly, then you can thread the screw in or out to adjust how far the TB will open.
02-11-2008, 10:11 PM #14
- Oct 2007
- Beaver Dam KY
Any pics of it tho>?? I thought about doing this... that way if i let my g/f ever drive my car i can crank it all the way out.. lol
02-11-2008, 10:48 PM #15
- Mar 2006
- WI
- Blog Entries
- 1
02-11-2008, 10:50 PM #16
- Oct 2007
- Beaver Dam KY
I told her as soon as she gets her license I would like her drive it.. my mistake.. a guy a couple of miles from me is going to do the bump stop mod for me and P&P..
I could always do the set screw anytime tho
TB Bump Stop Mod
By bhunter0830 in forum General HelpReplies: 9Last Post: 09-07-2012, 10:50 AM -
Bump stop ar-15
By bluehawk2000 in forum Gun's & AmmoReplies: 5Last Post: 03-07-2012, 04:44 PM -
bump stop question
By 99pewterta in forum Suspension and HandlingReplies: 6Last Post: 08-14-2009, 08:53 PM -
WTB bump stop!
By Justin23454 in forum Parts Wanted / TradeReplies: 0Last Post: 02-01-2008, 06:27 PM -
TB Bump Stop Mod ??
By 98redbird in forum External EngineReplies: 0Last Post: 12-13-2005, 08:12 PM
