Results 1 to 16 of 16
10-16-2006, 02:54 PM #1
- Apr 2006
- Kings Bay, GA
Black- 2000 Camaro SS
Help! Calipers dragging on disc brakes....
Just put new pads on my 2000 SS, now after the brakes are pressed, the front brakes drag on the calipers. Did I do something wrong or is it just because the pads are fresh and thick? Anybody? Somebody?...
10-16-2006, 09:47 PM #2
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Disc brakes ar constant friction, they will always have some drag on them.
10-17-2006, 04:19 AM #3
- Apr 2006
- Kings Bay, GA
Drag enough until the rims will burn the shit out of your hand and brakes smell? I can tighten the lug nuts firmly with the car sitting on jack stands and no brakes applied. I can barely spin the wheel.
10-17-2006, 07:02 AM #4
You have something wrong....did you pull & grease the caliper pins?
Did you push the pistons back into the the bore before installing pads?
10-17-2006, 07:51 AM #5
- Apr 2006
- Kings Bay, GA
Yes, greased pins, used old brake pad and c-clamp to push pistons back into calipers.
10-17-2006, 08:20 AM #6
10-17-2006, 10:19 PM #7
Yes, Severedistortion is correct in the fact the crap has to be cleaned from the caliper pin holes.
The calipers HAVE to float on the pins. Any crap will cause them to bind and prevent them from releasing.
Use grease made for this purpose, it's a special synthetic grease.
You might try flushing the old fluid.
If sludge has built up in the master cylinder, it may be preventing the calipers from releasing.
The other scenario is a possibility the pistons in the calipers are cocked in thier respective bores.
Is it both sides or one??
10-18-2006, 07:01 AM #8
- Apr 2006
- Kings Bay, GA
Both sides are stuck. And i flushed all four calipers until i had new clear fluid from the bleed port. Gonna try cleaning the pins and the holes. Thanx for all the help. And what kind of grease exactly should I use?
10-18-2006, 08:53 PM #9
10-19-2006, 03:37 AM #10
My wheels turn easily, with the pads barely touching when the tires are rotating.
SteveC
10-19-2006, 06:42 AM #11
- Sep 2005
- Austin, Texas, USA
I've seen bad brake hoses do this, they act like one-way valves. Used to be you never saw that but it is much more common now.
10-19-2006, 07:57 AM #12
- Apr 2006
- Kings Bay, GA
That was it!! After close inspection of one of the caliper pins found hard build-up of grease which was preventing proper sliding action. A little sanding, a good greasing, problem solved!! Thanks for all your input!!
10-19-2006, 10:02 AM #13
sweet
10-19-2006, 12:11 PM #14
10-19-2006, 12:18 PM #15
10-19-2006, 01:03 PM #16
Anyone know where you can but new caliper brackets? I had a pin seize up, and as a last resort I drilled it out, but I'd like to replace it just for good measure. Problem is I can't find them anywhere...
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
Help: Trying to go to disc brakes
By 1998 T/A in forum Suspension and HandlingReplies: 0Last Post: 01-05-2011, 12:54 PM -
Wanted: drilled/slotted disc brakes
By amysboxers in forum Parts Wanted / TradeReplies: 2Last Post: 10-01-2010, 06:07 AM -
Wanted: Rear Disc Brakes
By PsychMuscle in forum Parts Wanted / TradeReplies: 4Last Post: 06-17-2008, 02:05 PM -
disc brakes
By txman4362 in forum General HelpReplies: 2Last Post: 05-26-2007, 12:40 PM -
Braking Away: Upgrading the disc brakes on a 68-82 C3 Corvette
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-04-2006, 01:39 PM
