Results 1 to 20 of 21
03-08-2010, 12:57 PM #1
What's a good way to keep flywheel still?
Doing my research for my cam swap. I got a lot of parts ordered etc.
So I was wondering whats a good easy way to keep that flywheel still when I'm removing the crank bolt, also, are these crank bolts a bear sometimes? Should I spray some WD-40 er something on it over night?
03-08-2010, 01:42 PM #2
I suppose i could use a hefty screw driver.
03-08-2010, 01:49 PM #3
- Feb 2006
- Orange County, NY
Keeping the belts on until you get the bolt broken loose will help. Sears has a strap wrench that will help too.
03-08-2010, 01:53 PM #4
- Mar 2008
- NYC
Navy Blue Metallic- 2000 T/A Firehawk M6
i'm assuming you have an A4? me thinks it would take an unhuman amount of torque to move that flywheel if you had the car in gear on an M6....... unless you need a new clutch
03-08-2010, 02:13 PM #5
Yes, auto.
03-08-2010, 05:35 PM #6
03-08-2010, 05:45 PM #7
if you are changing belts you can wrap it around the pulley like a strap wrech and hold it that way. also they make a tool for holding the flywheel.
Mark
03-08-2010, 06:02 PM #8
Use an impact gun and you won't have to hold the flywheel....If you have access to an air compressor that is.
03-08-2010, 06:43 PM #9
I plan on having an air compressor around. Maybe someone will let me borrow an impact gun.
I planned on using the compressor for holding up the valves. Just doing some homework. Seems like this might get a bit tough, but it'll be worth it.
03-08-2010, 06:48 PM #10
http://www.etoolcart.com/flywheelhol...j-42386-a.aspx
That should work for removal and install. Can always sell it afterwards.370 CI - Twin 6766 Turbo - Jakes stage 5 4L80E - MWC 9" - Holley Dominator
Build in progress...
03-09-2010, 08:45 AM #11
Used my buddies snap on impact and it spun it off like a charm
03-11-2010, 12:51 PM #12
+3 or 4 on the impact. Just make sure you have the right size socket on it and that the socket is on the bolt right, before you pulll the triger.
03-11-2010, 01:06 PM #13
Sure you can use an impact to remove the balancer, but how you going to install it?
03-11-2010, 01:34 PM #14
Well I got the breaker bar and 23mm socket, if i remember the size off the top of my head.
Shouldn't be an issue tightening it. Breaking it loose can be a a bit tough I hear.
03-11-2010, 05:04 PM #15
engine wont turn as fast as the torque wrench lol. I just don't like turning the engine backwards.
03-12-2010, 05:09 PM #16
03-12-2010, 05:16 PM #17
IMHO,I really don't think the torque spec for the balancer bolt is that critical.Most of the time I use a 2 by 4 and a hammer to get the balancer started and then hit the bolt with the impact to bring it the rest of the way in.Have never had a problem doing it that way even though I know it's not textbook procedure.
03-13-2010, 07:02 AM #18
Important to use a new bolt when re-installing. The crank bolt is a "torque to yeild" design. It gets torqued to something like 30lbs & then tightened another 270 degrees rotation. I don't think I've ever made the whole 270, put a pipe on a breaker bar & give it all you can, will be fine then.
03-17-2010, 07:03 PM #19
I used a couple of screwdrivers wedged into the flywheel.....just takes some engineering to get them in there right and tight enough but they'll hold. I have an impact but the problem is my impact only goes to like 150 ft/lbs I think and wasn't strong enough to break the bolt loose. Are you putting a stock bolt back in or ARP? I went with ARP and it gets some ungodly amount of torque applied to it to get the bolt back on there.....like 240 ft/lbs I think. I did get the wrench to click but I couldn't tell if it was the wrench clicking or one of my vertebrae.
03-17-2010, 07:06 PM #20
it is pretty critical...at least on these cars. I can't tell you how many " my balancer bolt fell out" threads I've read over the years. I've also read a few " I stripped the threads in my crank" posts too from pulling the pulley on with a bolt.
One of those things where it's best to err on the side of caution IMO. You may get away with it 99 out of 100 times but that 100th time can be a pain in the ass.
good stall converter and sfi flywheel and other stuff
By jsmith564` in forum Parts Wanted / TradeReplies: 0Last Post: 02-01-2011, 05:48 PM -
Flywheel...
By LT4Hawk9 in forum Manual TransmissionReplies: 1Last Post: 03-07-2009, 03:16 PM -
FS: New OEM LS1/LS6 Flywheel
By RaceDriver in forum Parts For Sale / TradeReplies: 10Last Post: 08-30-2006, 07:35 PM -
Bad Flywheel?
By 1SSWFO in forum Manual TransmissionReplies: 3Last Post: 09-21-2005, 06:04 AM -
flywheel 94
By TONY in forum Western MembersReplies: 1Last Post: 08-29-2005, 10:14 PM
