Thread: Backfire?
08-08-2009, 09:56 AM #1
- Sep 2005
- Northern California
Arctic White- 98 Z-28
Backfire?
The last few nights after work I start my drive home and when I hold third gear at about 2K rpm and let off the gas there seems to be a slight backfire. Car runs fine and doesn't really do it when it gets warm. Is this normal? No other symptoms; just sounds like its shooting ducks.
08-08-2009, 10:45 AM #2
6sp auto? If you just let off the gas while in gear you can expect that to happen.
08-09-2009, 03:27 PM #3
- Sep 2005
6sp...guess that's normal then.
08-09-2009, 03:40 PM #4
Same happens to me. I was told it was normal too
2001 Camaro SS M6 SLP LMII, Lid
1987 iroc-z RIP 5.7 TPI Full exhaust, lingenfelter intake runners (gone but not forgotten)
1991 bmw 325i DD
08-09-2009, 08:14 PM #5
An exhaust leak can cause it also.
08-12-2009, 10:42 PM #6
It could be the Check Valves for the A.I.R. system that mount to each exhaust manifold. That's if you haven't removed it yet.
08-19-2009, 06:46 PM #7
i had same problem. probably an exhaust leak. but when i deleted the AIR system it took care of itself. no more backfiring
00 Trans Am:LS1-M6-SLP loudmouth 1-Lid-Bellows-CAI kit-85mm MAF-B&M ripper shifter-Torque Arm-LCA-Panhard Bar-STB-EGR AIR delete
This winter: Torquer V.2-LS6 intake-LT's-Monster clutch-Custom y-pipe-and a really good tune
Backfire
By 98warbird in forum General HelpReplies: 1Last Post: 12-22-2008, 03:41 PM -
Question: !!!!backfire!!!
By pmolina0436 in forum GTOReplies: 20Last Post: 09-27-2008, 08:15 PM -
Some causes of backfire
By chuckie669 in forum General HelpReplies: 9Last Post: 05-20-2008, 02:56 PM -
Need Help with backfire!
By borgejr in forum General HelpReplies: 0Last Post: 08-10-2007, 08:41 PM -
Backfire
By feet739 in forum Internal EngineReplies: 10Last Post: 09-21-2006, 05:23 PM
