Results 1 to 11 of 11
    Member joker's Avatar
    Feb 2006
    North Carolina
    2002 Pontiac Trans Am WS6
    Power window motors
    I have been going through these motors every year. Anyone else having this problem
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    where do you get them fixed at?
    Senior Member
    Jacksonville, FL
    Get one locally with a lifetime warranty...and do it yourself, shbox.com has a guide.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    Yes they are a weak spot on our rides. Get the Autozone replacemtn ones with lifetime warranty
    SATX
    2002 TransAm Firehawk
    Are you guys doing these motor replacements by yourself?
    I had the door apart and could not feasibly see a way to get the motor back there and hold it in place while bolting back up. So I put the damn door back together and took it too a shop. My passenger side is now going and I want to do this myself. Am I gonna need a buddies help?
    Bragg NC
    Met. Sunset Orange
    01 SS
    I did mine myself. Might make things a lil easier with a buddy but is easy too do alone. I got mine from chinazone with the whole lifetime warranty deal and so far so good.
    J
    Boulder, CO
    you can do it by yourself you just need patience. http://shbox.com/page/windowmotor.html
    Senior Member
    Jacksonville, FL
    You can do it - to get the motor back there just remove the speaker.
    Junior Member 2CMX's Avatar
    Alexandria, VA
    99 Z
    It is pretty easy. I drilled out the old rivets(Yes I drilled through the fiberglass to get to the rivet), slid the new one into place figured that I couldn't get a rivet gun back in there and just used bolts and locknuts on the existing holes. took about 1.5 to 2 hrs.
    I flame retards CamaroFan71's Avatar
    Aug 2006
    Baton Rouge, La.
    QuickSilverMetallic
    2005 GTO M6
    Whats the story with the motor mod that makes it roll up faster? Something about doing away with a safety on the motor?
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    yea, i want to do the overheat override on my window motor to save some $$ plus i dont want to be doing another failing motor in the future.
  1. Help: Both power window motors at once?
    By SteveCZ28 in forum Stereo and Electronics
    Last Post: 01-09-2010, 06:03 PM
  2. Help: replacing power window motors 94 camaro
    By adrenalinejunkie in forum General Help
    Last Post: 07-10-2009, 12:53 PM
  3. Question: installing power window motors
    By roger99 in forum General Help
    Last Post: 10-18-2008, 06:51 AM
  4. Power window motors
    By patriot1136 in forum General Help
    Last Post: 09-10-2007, 09:44 AM
  5. WHat size rivets for power window motors?
    By MagicMan in forum General Help
    Last Post: 08-18-2006, 11:54 AM
