Results 1 to 14 of 14
Thread: is this my alternator?????
01-17-2008, 02:59 PM #1
well car runs fine/starts for a day, then will be dead next moring. soo i jump it then runs fine. 93 saturn
and if this is it how hard is it to install
01-17-2008, 05:25 PM #2
Get it running & then unhook the neg battery terminal. If it stays running, the alternator is OK...
01-17-2008, 06:38 PM #3
That is a good way of killing your computer with a voltage spike. That trick may have worked good on older cars that had no computer and other electrical acessories that are sensitive to spikes in the voltage to them, but not on newer cars.
I would take the car to a parts store and have the battery and charging system checked.
01-17-2008, 06:51 PM #4
01-18-2008, 02:59 AM #5
Good Point...
01-18-2008, 08:30 AM #6
^^Yup. If the car stays running, I'd look at the battery. If the alt was the issue, the car wouldn't run for long (until the battery drained).
FWIW, I've had issues w/ O'reilly's batteries. Never had problems w/ Walmart's cheapo's.
01-18-2008, 11:46 AM #7
If the alt is going bad usually the headlights will be dim. But yeah go to a garage and have them check it for you-those morons at Autozone aint hookin shit to my car.
01-18-2008, 06:19 PM #8
good rule of thumb, with the car off the battery should read around 12 volts. Start the car and test again you should be getting around 14 volts. Take readings at the battery.
01-18-2008, 06:20 PM #9
01-19-2008, 11:19 AM #10
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
check the battery terminals. I had a car do this to me then after messing with it I learned that my positive cable was bad, car would be totally dead so I would pop the hood jiggle the positive cable and all the sudden the under hood light would come on and car would start. Replace the positive cable and no more problem. Just my expirience.
01-19-2008, 07:18 PM #11
- Jul 2006
- Glen Carbon, IL
Silver- 2000 Camaro SS
Start car and put voltage tester on battery termials to check voltage, anything 13.5 and above is good. I just had to put an alternator on my DD and voltage running was 11.98 with bad alternator and 14.4 with new alternator.
01-20-2008, 02:50 PM #12
thanks everyone auto zone here i come
01-20-2008, 08:02 PM #13
- May 2007
- Phoenix, AZ
For one- Looking
More than likely it is the battery. If the engine dies while running, its the alternator. If you are able to start it with a jump, but then after you turn it off it needs another jump, The likely culprit is the battery as it may only be getting a surface charge.
01-22-2008, 05:14 PM #14
well the battery is 3 months old. .1st treid jumping it today , and noo go no power . but after slamming the door ( i was pissed) the lights came on.
i guess there is just a loose ground somewhere, soo thats how i have to start it now LOL
Alternator help
By GOHOME! in forum General HelpReplies: 3Last Post: 06-06-2009, 11:18 AM -
Need Help With Alternator!!
By camarossf650 in forum General HelpReplies: 11Last Post: 03-20-2009, 05:42 AM -
Alternator Help
By Chamelion WS6 in forum General HelpReplies: 4Last Post: 12-16-2006, 08:13 AM -
alternator
By a10beav in forum GTOReplies: 2Last Post: 09-26-2006, 08:39 AM -
lt1 ALTERNATOR
By drb131s in forum Parts For Sale / TradeReplies: 0Last Post: 09-17-2006, 04:16 PM
