Results 1 to 16 of 16
Thread: Which fuel pump??
08-07-2008, 07:28 PM #1I flame retards
- Aug 2006
- Baton Rouge, La.
QuickSilverMetallic- 2005 GTO M6
Ima blow it up!!
Was coming home, car started running like shit. Second gear, 25-30 mph with the car floored and it would barely run. No ses light or anything came on. Got home and took the lid off ane cleaned the maf with maf cleaner and the t/b with t/b cleaner. Also took the time to spreay down in between the radiator and a/c condensor as it was filthy. Put it back together and started it up, while revving it up from under the hood, it would barely idle. This is the first time in a while its acted like this, usually it misses/stumbles after it gets hot. And of course, right before I kill it to go inside (before I blew it up, cause I was trying too) the fucking ses light comes on. Having it scanned tomorrow.
New alternator..
New TPS..
And ideas????
08-07-2008, 07:41 PM #2Slow'er'Ass
- Thornton, CO
And recent changes??
Check plug wires, all sensor connections.
If that doesn't do it, when was the last plug change? Maybe a fouled plug?
I bet you get the SES light soon.
08-07-2008, 07:49 PM #3Member
- Jul 2008
- cali
red- 1998 z28
maybe plugs
08-07-2008, 08:43 PM #4
08-08-2008, 01:33 PM #5I flame retards
- Aug 2006
- Baton Rouge, La.
Fuel pump going out and relay drawing too many amps!!!! $1280 worth of nut kicking shit!!
08-08-2008, 01:49 PM #6I flame retards
- Aug 2006
- Baton Rouge, La.
Which fuel pump??
Delphi or racetronix??
08-08-2008, 03:03 PM #7
Racetronix
08-08-2008, 03:28 PM #8Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
how can a relay draw too many amps? is it going bad?
08-08-2008, 08:02 PM #9
replace that pump yourself. Racetronix kit at harris speed works for less than $300 if I remember correctly.
08-08-2008, 08:18 PM #10I flame retards
- Aug 2006
- Baton Rouge, La.
Yeah thats what the guy said.
With it being the weekend Im severely crunched on time, as its in the shop and torn down. The guy is cool enough to give me the weekend to try and find a better and less costly pump to put in, but I'd have to have the pump by monday morning. Thunder Racing said 2 weeks on the Racetronix. I'd do it myself but I dont have the place or means. Sucks cause that money was going to be my header money
08-08-2008, 09:26 PM #11
you should get in touch with Matt at harris tomorrow. Call them, they may overnight one to you that would be here Monday. Even paying the extra shipping you'd probably still come in under the stock pump.
08-08-2008, 09:27 PM #12
I'm going to merge your 2 threads.
08-09-2008, 07:55 AM #13I flame retards
- Aug 2006
- Baton Rouge, La.
www.harrisspeed.com is that the place? Thanks Orion!!
It comes up as harrisspeedworks.com and says theyre closed today. Dammit!!Last edited by CamaroFan71; 08-09-2008 at 08:00 AM.
08-09-2008, 09:31 AM #14
yeah, that's it. You could also try thunder racing....they're based out of Louisiana.
08-09-2008, 10:40 AM #15
08-09-2008, 11:06 AM #16
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2011, 09:20 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM -
Fuel Pump Pump Problem?????? Help!
By undertakersT/A in forum General HelpReplies: 4Last Post: 04-24-2006, 09:55 AM
