Thread: Nitrous Install Pics
01-04-2007, 08:14 AM #1
Took a couple of pics with it almost completed. I have to run the main feed line now and that is all. Everything is all wired up. I also took the valve covers off and painted them and the throttle body. I also deleted the pcv system and put a metco breather on.
01-04-2007, 10:49 AM #2
looking good
01-04-2007, 12:43 PM #3
I like where you mounted the bottle. I saw something like that in a video, where the bottle was behind the trunk paneling, but he turned the bottle on and off through the speaker panel where the factory sub was. Completely hidden...it was sweet.
01-04-2007, 05:30 PM #4
Alot of people mount the bottle there. I just havent seen it done like mine. I might cut a design into the wood with a scroll saw and stain it.
01-08-2007, 11:14 PM #5
Here is a old pic I found of a NitrousDirect 2 Stage 90mm LS2 Plate with one stage hooked up. We run the longer nitrous line cause it softens the intial hit.................
01-11-2007, 10:38 PM #6
Heres a pic of NX's 500hp carb plate kit with the 300hp jets shooting up doing a flow test. It uses a -6 hose to feed the nitrous solenoid.
Nitrous Install, Help
By Raoul-Duke in forum NitrousReplies: 10Last Post: 05-03-2010, 10:47 AM -
nitrous install
By LS1MuNkY in forum NitrousReplies: 9Last Post: 12-15-2008, 01:18 AM -
Nitrous install pics (please)
By 05gtoautoX in forum GTOReplies: 9Last Post: 03-19-2008, 07:55 PM -
Bayarea...Nitrous install? recommend me a shop or member to do the install? Price?
By 2klude in forum Western MembersReplies: 5Last Post: 04-11-2007, 09:30 PM -
? on nitrous install
By jwcardy in forum NitrousReplies: 9Last Post: 12-06-2005, 07:16 PM
