Results 1 to 20 of 26
Thread: ABS Inop & Trac Control Off
11-05-2008, 07:17 PM #1
- Dec 2006
- Pensacola
Red- 2001 Camaro SS A4
Okay..so the first 2 things I am going to have to fix on the SS are these two lights
the ABS Inop light is on...and does not go off
And the "Traction control off" light will not go out (maybe a logic box?)
Where do I start?
11-05-2008, 08:40 PM #2
The "Trac off" light is on because of the ABS problem. Diagnose that first.
11-06-2008, 11:12 AM #3
- Dec 2006
- Pensacola
what could be the problem?....a sensor?
11-06-2008, 04:40 PM #4
It could be a wheel speed sensor (which is most common) or a pump circuit fault ect... there are multiple ABS codes so until someone is able to pull the code your shooting in the dark.
11-06-2008, 04:55 PM #5
check the ground on the radiator support....mine had those lights on and that is what it was
11-06-2008, 05:58 PM #6
- Dec 2006
- Pensacola
sweet...i think i might know another reason...when i went to drive the car the left front tire was way low...possible cause being different wheel spin speeds?
11-06-2008, 06:06 PM #7
Could be. Unhook the battery and reset the computer. A wheel speed sensor that is inoperative will set a code right away.
11-06-2008, 07:23 PM #8
- Dec 2006
- Pensacola
getting the codes checked on tomorrow during my tune
11-08-2008, 07:29 AM #9
- Dec 2006
- Pensacola
Ok i got a friend to shoot some codes for me and we found these two
C0050 - Right rear wheel wheel speed circuit malfunction
C0046 - Left rear wheel speed ciruit range/performance
But I have no sensors on my rear wheels
anybody else run into this problem?Last edited by blackhawk01; 11-08-2008 at 07:43 AM.
11-08-2008, 07:46 AM #10
well now, your not going to have sensors on your wheels if that was where you were actually looking. they are in the end of your axle, where your brakes mount up. also c0050 is right rear wheel. i doubt that you have to bad wheel speend sensors at the same time. so what you do is look at a schematic and find what the two circuits have in common, prolly a connector somewhere and it could have come unplugged or have corrosion. check this connector: #1
11-08-2008, 07:57 AM #11
- Dec 2006
- Pensacola
ah...sweet..so now I dont think I have the right rear end in my car lol..I have no sensors or wires back there and I came across one of the plugs on the gas tank not being plugged in...
also..the pumpkin has the number 26041414 for the stock number
11-08-2008, 08:07 AM #12
i dont know what that particular connector is. did you just buy the car? does it have a asr button next to the fog light button? has the car always been throwing these warning lights?
11-08-2008, 08:09 AM #13
- Dec 2006
- Pensacola
12570109 is what GM told me it should be...this possibly might be a V6 or LT1 rear end because the rear brakes are kind of small ...
11-08-2008, 08:11 AM #14
11-08-2008, 08:31 AM #15
i bet it did. prolly got a regular rear with no asr. i think the brakes are all the same for the 98-02 years regardless of engine size if they are disc. lol i dont know what to tell you except get a 12 bolt with asr hook ups
11-08-2008, 08:47 AM #16
- Dec 2006
- Pensacola
well I did double check on the brakes and compared it to a firehawk sitting out in the dealership and sure enough the brakes are different and there is a plug in that spot where there is not on mine
11-10-2008, 12:03 PM #17
- Feb 2006
- Orange County, NY
Someone probably switched in a rear from a car with 3 channel abs instead of one with 4 channel. The 4 channel is for traction control cars.
11-10-2008, 12:34 PM #18
11-10-2008, 01:52 PM #19
- Feb 2006
- Orange County, NY
Just as long as it is a 4 channel abs setup. I think it should have sensors on hubs and 2 seperate brake lines.
11-10-2008, 02:41 PM #20
- Dec 2006
- Pensacola
the salvage yard called me and verified with me that the axle came off of a 2000 car with 49k on the clock..and it does have the sensors for ASR
what is the difference in a 3/4 channel? just a question out of curiosity
Low Trac, then INOP
By manarth5103 in forum General HelpReplies: 7Last Post: 09-25-2009, 02:40 PM -
Trac off light on
By derck_mullin in forum General HelpReplies: 2Last Post: 04-22-2009, 05:25 PM -
LOW TRAC ? om a 93 LT1 Z-28??
By troopermc in forum LT1Replies: 6Last Post: 11-10-2008, 01:54 PM -
Low Trac light??!! Need help please!
By Hi-Po in forum External EngineReplies: 25Last Post: 11-06-2008, 04:06 PM -
Low Trac ?
By driving in forum General HelpReplies: 5Last Post: 02-11-2007, 10:08 AM
