Results 1 to 20 of 38
Thread: 10bolt build up?
12-07-2006, 12:36 PM #1
- Oct 2006
- Seaford
Black- 2001 Trans Am
10bolt build up?
ok, let me start by sayin i am really confused, so help me out if you can, i jus bought a set of bfg drag radial 2's so this topic is important to me, can a 10 bolt be built up so it doesnt break? or do you have to go with a 12 bolt in order to maintain your rear? if a 10 bolt can be built up, where could you have it done or where could you get the parts? any info would help me greatly
12-07-2006, 01:01 PM #2
I am interested in the same thing...
12-07-2006, 01:04 PM #3
- Mar 2006
- LS1 land
generally everyone says not to waste $ on your 10bolt. Just save for the 12bolt. But i think a rear end girdle would help it last a little longer.
12-07-2006, 01:07 PM #4
do you have a link to such a part, i am assuming it will strengthen the 10 bolt.
12-07-2006, 01:12 PM #5
- Mar 2006
- LS1 land
i read an article in gm high tech saying that it will help it last longer/ hold up better.
They are on many websites and from many companies. But i think they are all pretty similar.
http://www.lmperformance.com/681/1.html
12-07-2006, 01:18 PM #6
With an M6 car running slicks you are almost guarenteed to have to buy an aftermarket rear. The A4 cars are a lot more gentle on the rear. There are some running in the 9's with a 10 bolt behind an A4 trans. If you are running big hp with an M6 you are better off to go with a 9" because even the 12 bolt will break.
12-07-2006, 01:22 PM #7
12-07-2006, 01:35 PM #8
- Oct 2006
- St. Clair Shores. Michigan
You can build a 10 bolt to hold up to approx 425 RWHP.
You need to Weld the axle tubes install a good Carrier, Gears, Axles(31 spline) and a T/A Girdle. They did it in a previous issue of High Performance Pontiac Magazine. And it was well under $1000.
12-08-2006, 12:43 PM #9
If I were you and running the A4 I wouldn't worry about the rear until it started making noises or giving me problems.
12-08-2006, 04:30 PM #10
12-08-2006, 07:32 PM #11
- Nov 2005
- College Station TX
Black- 2000 &2002 Z28
ouch he just raised the bs flag.....
Lol man.......just give up on it man.....trying to build up a 10 bolt besides just a cover is like ricers trying to build up their little 4 bangers.....
Cost way too much and aint worth it....
SOrry man......If u got the money and the opportunity save up for a 12 bolt
12-09-2006, 01:49 PM #12
Termin8tr on tech was running a 10 bolt/M6 setup making 490rwhp + nitrous and never broke the rear but he has since went with a 9".
12-09-2006, 03:47 PM #13
- Jun 2006
- Arnaudville, LA
Bright Rally Red- 01 Camaro SS M6
I am running just north of 500rwhp & 500rwtq with the 10bolt M6 on Nitto DR's.....I run Motive 3.90's with the T/A cover. I keep the 60's nice and soft 1.8's and that allows me to run 11.4's @ 127. Oh, I don't powershift either. I have also run 4.10's and 4.30's in this rear.......broke 4 teeth off the 4.10 ring gear when I got some really bad wheel hop, learned a lesson!!!
Keep in mind I leave the line just above idle 1100-1400rpm and back out of the clutch "kinda" quick.
12-10-2006, 07:15 PM #14
buddy of mine has a 85 regal/chevy 350/2600lb with him in it ..........broke one axel running mid 12s.........another running mid 11s.....bought moser axels........then stripped the teeth of 2 ring and pinion gears 4.56 running 11 teens.........then went to 9"..........i have a 7.5 in my monte carlo his old axels 4.56 gears.....no problem yet running 12.20s 2700 w/ me in it but just got a 8.5 10 bolt im going to build up....it should hold at least mid 10s with 33 spline axels.............another guy i know has a 69 nova with a 8.2 10 bolt....its a frankinstien rear end with a ford 8.8 ring gear and 33 spline axel....first i had ever heard of something like that
2002 Chevrolet Camaro Z28 m6
SLP LoudMonth, SLP CAI, SLP MAF, Hotchkis SFC
12.76 @109 1.96-60ft
12-11-2006, 06:19 AM #15
- Aug 2006
- illinois
red- 99 Z28 SS convertible
ok. thats why my 'vert SS and Ed's 'vert at 3850 w/ driver are in the 10's w/ 10 bolts. and holding up. his is stock, mine has solid spacer, richmond gears, new Eaton posi, LPW girdle. stock axles and running slicks! goes to show that an A4 w/ 500+ rwhp will live.
im not telling A4 guys to not buy a better rear end, just that theres living proof that the 10 bolt will go a for quite a while.
12-11-2006, 03:55 PM #16
12-11-2006, 05:52 PM #17
12-11-2006, 05:58 PM #18
12-11-2006, 05:59 PM #19
Wrong again!!!!!
12-11-2006, 06:07 PM #20
Wanted: Stock 10bolt, 3 channel, 3.23 out of a A4 ws6.
By BlackPearl in forum Parts Wanted / TradeReplies: 1Last Post: 05-22-2012, 03:34 AM -
good old 10bolt....
By camarospade in forum DrivetrainReplies: 26Last Post: 02-26-2010, 01:28 PM -
10bolt going up for sale(if anyone wants a spare)
By z28misfit in forum Parts For Sale / TradeReplies: 3Last Post: 02-10-2007, 01:01 PM -
WTB! wheels and 10bolt needed.
By ibanez7 in forum Parts Wanted / TradeReplies: 3Last Post: 03-10-2006, 07:20 PM -
WTB 7.5 10bolt for 02 WS6 with TCS in Texas
By mark78 in forum Parts For Sale / TradeReplies: 0Last Post: 11-02-2005, 11:47 AM
