Thread: A/C wont blow out of dash vents
07-27-2011, 05:22 PM #1
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
well i havent really messed with it because i never use the a/c on my car but today i was checking it out and the vents in the dash wont blow air. the defrost and the floor vents will but nothing when i switch it to the middle ones. im assuming that this had been like this since the cam and head install. i checked the back of the intake and it looked as though all the vacuum lines were hooked up so im stumped at what it could be? any suggestions?
2000 ss camaro, forged lq9 370 short block, stage 3 PRC 243 heads, fast 102 w, big mouth throttle body, MS3 cam, 1.7 roller rockers, stage 3 t-56, monster stage 3, pro 5.0, 4.10's with moser axles, bmr tq arm, lca's, phb. SOLD (thankfully)!!!
New project: 1968 step-side, partial restore, ls/th400 swap. hopefully boosted pics and more info to come!!!
Having a small cam is like having a small dick, everytime you go to use it you wish it was bigger
07-27-2011, 07:45 PM #2
My vacuum check valve broke on the passenger side close to the firewall and caused the same thing. Assuming what you checked were the lines that go behind the engine to the AIR solenoid, you may have missed that valve
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
07-28-2011, 02:22 PM #3
- Aug 2010
is there a way i can test it with out just repalcing it? and do you have more of an exact location?
07-28-2011, 03:11 PM #4
Don't mind the filthy engine bay. It's the 3 way valve directly to the right of my hood strut. It has a clear top but the old one was solid black. Mine was obviously broken but if you have someone help, you could pull each of the lines that don't go through the firewall and block it off at the valve. If your hvac controls start working then you know which line to follow for your problem. Like I said my valve was clearly broken so all I had to do was replace it.
Hope this helps
08-03-2011, 12:28 PM #5
- Aug 2010
Thanks man i will check it out when i get off work tonight
08-03-2011, 04:32 PM #6
No problem. Let me know what ya come up with
HVAC VENTS and Plastic 3 way valve (defrost to vents)
By barberjd in forum Firebird / WS6Replies: 3Last Post: 08-27-2023, 05:17 PM -
Help: Emergency !!! Dash lights flashed on -wont turn over
By specialk1211 in forum General HelpReplies: 4Last Post: 06-25-2013, 09:04 AM -
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Wanted: Firebird Dash Vents
By TransAmX2 in forum Parts Wanted / TradeReplies: 0Last Post: 09-22-2010, 04:59 PM -
Dash Pad Needed (upper Dash)98-99***
By LETHALxLS1 in forum Parts Wanted / TradeReplies: 3Last Post: 01-20-2007, 11:10 AM
