Results 1 to 14 of 14
Thread: Engine overheats after shutdown
09-03-2009, 05:09 PM #1
- Sep 2009
- Lakewood Colorado
Red- 97 WS6 Ram Air T/A Conv
My 97 Trans Am with WS6 and Ram Air only overheats after you shut the motor off.
Is there a temp sensor that is supposed to keep the fan on until the engine cools?
Thanks in advance,
George
09-03-2009, 05:38 PM #2
All engines heat soak after you shut them down. For a brief period the temperature will climb as the coolant absorbs heat from the engine. Even if the fans continue to run after shut off, they simply cool what fluid is in the radiator. At best, there may be some very minimal convection circulation until the thermostat closes since the water pump is no longer turning.
How hot does it get and have you checked it with a scanner?
09-03-2009, 06:22 PM #3
09-04-2009, 01:20 AM #4
If it gets that hot after shut down it may be running too hot to begin with. I would check the cooling system and make sure everything good and have the cap checked to make sure it is holding pressure.
There is also an option in the tune to allow the fans to run after shut off.
09-04-2009, 03:10 AM #5
How do you know its over heating?
Our gages arent very accurate..
09-04-2009, 03:18 AM #6
- Sep 2009
- Lakewood Colorado
There is one thing that happened the other day. There was a plastic valve of some sort in the one of the heater hoses. It was near the pump itself. It broke after parking the vehicle. I assume it was so hot that the pressure in the hose broke it. I didn't replace the whole hose, I just bought a 3/4" splice and some clamps to get the car running again.
What was that valve for? I noticed it had a pencil size hole inside to let the fluid through to the heater core.
Thanks, George
09-04-2009, 03:25 AM #7
09-04-2009, 03:30 AM #8
09-04-2009, 03:33 AM #9
09-04-2009, 03:36 AM #10
09-04-2009, 03:45 AM #11
09-04-2009, 03:46 AM #12
That's a flow restrictor to so that you don't get too much pressure from the cooling system into the heater core. Be sure to replace it 'cause you don't want to blow the core. BTW if your car has not been thoroughly flushed and new antifreeze put in you should do that. The LT1s have a good deal of problems with antifreeze contamination.
09-04-2009, 03:54 AM #13
09-04-2009, 05:42 AM #14
- Sep 2009
- Lakewood Colorado
I usually gets what I wants...you got a problem with dat?
Shutdown! Senate Refused to Negotiate w/ House...
By wileyCoyote in forum Political / Debate ForumReplies: 122Last Post: 10-17-2013, 03:50 PM -
Question: changed thermostat to 160 now overheats
By booyako in forum General HelpReplies: 16Last Post: 07-28-2010, 12:44 PM -
Car overheats at highway speed only! 60 and above!
By ItalianSS in forum External EngineReplies: 12Last Post: 06-27-2009, 07:38 PM -
Question: car overheats when ac is turn on?
By arnoldonsite2 in forum General HelpReplies: 10Last Post: 08-07-2008, 02:36 PM
