Results 1 to 13 of 13
06-27-2009, 12:06 AM #1
- Aug 2006
- New Jersey
White with Black Stripes- 1999 SS Camaro
Car overheats at highway speed only! 60 and above!
Started having this problem where I would take my ride on the highway, and after about driving a few minutes over 60mph, the temp gauge would start to rise and hit the red. After slowing down to about 45mph and driving like that the rest of the way, it would cool off and be fine. So what's the deal? Is it the waterpump?
Thought so too... Just replaced it today, took it for a test drive and it still does it! What could it be? Do I need to flush the system? Do I need to check something else? Before I poured that dex-cool into the engine and waste it, I just used regular water to see if it would still overheat, and it did... so now what? Anyone else have this problem? Thanks
06-27-2009, 02:31 AM #2
- Nov 2006
- Indianapolis
My first thought is to make sure the air dam under the car is there. It directs the air up into the radiator at highway speeds. I know the 3rd gen cars were picky about this problem exactly, I bet our 4th gens are the same.
06-27-2009, 02:33 AM #3
- Oct 2007
- Beaver Dam KY
Air dam, trash bag on on it, maybe even hose out the radiator from under the car. I cleaned mine out and it dumped all kinds of black crap out.(Cleaning from outside)
Also did you change your thermostat?
06-27-2009, 07:55 AM #4
Have you flushed your radiator? Trash can cause your thermostat to clog and overheat your car.
06-27-2009, 07:59 AM #5
- Aug 2006
- New Jersey
I remember like 1-2 years ago, I bought that 160 degree Thermostat. How do I test it? Also, I cleaned the radiator's outside and there was little debris, but it wasn't major. No plastic bags stuck to it, and as for the air dam under it. Well, I took mine off a few years ago. I was tried of hearing it scrape everywhere I went. BUT...... Here's how I know it's not that. I changed my hood, and added a Volant intake, the opening of the new hood, matches the volant really good. I mean, I could put the air dam on and test it out... but like I said, I started having problems a few years down the road, but will try that out. Thanks.... Anything else?
Also, when it's cooler out... or night time, I could probably stay above 60 and the car won't over heat! WTF?
06-27-2009, 09:20 AM #6
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
put the thermostat in a pot of water and put it on the stove. as the water heats up the thremostat will open.
06-27-2009, 12:55 PM #7
Also if your car overheats just one time your coolant is useless and your car will continue overheating as it was for my case. Could be your thermostat, also make sure your fans are working properly.
06-27-2009, 02:52 PM #8
I had that problem in an 85 IROC and it was 20 degrees out side the thing would go up to near red and then open for a minute and then close again and go back up to the red while I was driving 65 on the Hwy. Changed the thermo and problem solved
06-27-2009, 02:54 PM #9
- Aug 1999
- Arizona
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
06-27-2009, 05:45 PM #10
I can't believe you have run it that long without an air dam. As far as I know, the temp gauge in your '99 is an approximation at best. Have someone check your temp with a scan tool or use a laser temp gauge on the thermostat housing to get an idea. Did you re-program your fans for the 160 degree stat?
06-27-2009, 05:58 PM #11
06-27-2009, 07:37 PM #12
- Aug 2006
- New Jersey
06-27-2009, 07:38 PM #13
- Aug 2006
- New Jersey
Question: changed thermostat to 160 now overheats
By booyako in forum General HelpReplies: 16Last Post: 07-28-2010, 12:44 PM -
Question: Engine overheats after shutdown
By geoholt3 in forum General HelpReplies: 13Last Post: 09-04-2009, 05:42 AM -
Question: car overheats when ac is turn on?
By arnoldonsite2 in forum General HelpReplies: 10Last Post: 08-07-2008, 02:36 PM -
Highway RPM w/ 3.73s vs 4.10s
By bigcraig987 in forum DrivetrainReplies: 2Last Post: 05-04-2006, 08:26 AM
