Results 1 to 15 of 15
09-12-2005, 07:57 AM #1'00_ZGuest
yes its another header question...
would I be better off getting headers with emissions fittings or without? My car is a daily driver when I need it to be. Do the non-emission headers require different tuning?
09-12-2005, 07:59 AM #2
- Aug 1999
- Arizona
It all depends if you need to pass smog.
09-12-2005, 10:07 AM #3
- Yardley, PA
Black- 2001 Camaro SS
get them with, you can always block them off if you decide to remove the AIR system
09-12-2005, 01:17 PM #4
- OC, California
Arctic White- 1999 Z28 M6
ed do you not have to smog your car?
09-12-2005, 08:17 PM #5'00_ZGuest
No I don't have to worry about emissions testing. I'm just curious as to whether there would be any difference performance-wise. I will get the set with. Thanks guys.
09-13-2005, 05:07 AM #6
- Dec 2002
- n/w chicago
performance wise, im gonna say no difference.
a few bolt ons, 379 rwhp
11.96 @113.25
09-13-2005, 12:28 PM #7Snake EaterGuest
emissions fittings are pretty much cats right?
09-13-2005, 03:15 PM #8
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
Ed's car is all about smog! Im running race headers(no emission fittings) and it looks so much better in there. You can either get headers for 98-00 that have AIR and EGR or you can get 01-02 headers that have AIR only. It all depends on what you wanna do.
Originally Posted by snake eater
09-13-2005, 08:29 PM #9'00_ZGuest
Without the cats I won't need the AIR fittings, but what about the EGR? Will blocking it off or getting rid of it have any adverse effects?
09-14-2005, 02:20 AM #10
- Dec 2002
- n/w chicago
Originally Posted by '00_Z
09-14-2005, 05:38 AM #11'00_ZGuest
Thanks for all the input guys!
09-14-2005, 04:00 PM #12
- Yardley, PA
while you're at it, remove the air pump and hoses. This will clean up the engine bay, and save about 10 pounds.
01-04-2006, 05:21 AM #13
- Jan 2006
- Pennsylvania
I am of the old opinion that unless your getting long tubes dont bother with headers. The stock manifolds arent super restrictive on these cars. I have seen guys go from stock mani to Mac shorties and not even run a tenth better.
01-04-2006, 09:40 AM #14
- Crystal Lake IL
Pewter- 2001 Camaro Z28 M6
I live in IL where there is frequent emission test. My Z28 m6 is running LTs ORY without cats, in order to pass the emissions test, I had the O2 sensor ses codes deleted. So now my car passes all ODB emissions tests.
Usually if you pass that you wont have to do a sniffer test.
Just remeber when running catless, you will smell the unused fuel. so it will smell as if you car is running rich when it isnt.
Also for the AIR and EGR provisions, block off plates will work fine! w/o any problems
01-04-2006, 03:28 PM #15Originally Posted by ibanez7Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
once again a header question
By bmwmteam in forum External EngineReplies: 5Last Post: 05-04-2009, 06:46 PM -
Header question
By LETHALxLS1 in forum External EngineReplies: 238Last Post: 01-24-2008, 05:33 AM -
Header Question
By garver in forum External EngineReplies: 5Last Post: 11-11-2007, 05:25 PM -
Header Question
By fastfirebird2002 in forum External EngineReplies: 1Last Post: 05-21-2007, 03:12 PM -
Header Question
By TransAm45 in forum LT1Replies: 5Last Post: 01-04-2006, 05:18 AM
