Thread: Steering wheel shake
02-12-2006, 04:22 PM #1
- Columbus Ohio
Silver- At least its paid for.
When im going from about 40 or so and up my steering wheel starts to shake. What might be the problem? Thanks
02-12-2006, 05:52 PM #2
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Wheel balance or bad front end parts comes to mind.
02-12-2006, 05:59 PM #3Originally Posted by Johny Utah
02-12-2006, 06:31 PM #4
- Tulsa,OK
Quick Silver- 2002 Z06
Most likely and wheel balance or tie rod issue like they said above. My experience with balance issues would lead me to believe you had some front end hardware issues though. Most of the time when its a wheel balancing problem is doesn't show itself until 60 or so. Take it to a shop and have them balance the tires then go from there. Any good alignment shop will help you figure it out.
02-12-2006, 06:53 PM #5
As a general rule of thumb-wheel balance problems show up at 35 mph and up.A bad tire will shake at lower speeds and might smooth out at higher speeds.It could be a bent wheel also.Of course have someone experienced shake down the front -end while checking this stuff out.
02-12-2006, 06:54 PM #6quicky06Guest
can you feel it in the pedals?
02-13-2006, 04:41 AM #7
- Columbus Ohio
Good hopefully it just needs balanced then. I will take it in and see. Thanks everyone
02-13-2006, 04:42 AM #8
- Columbus Ohio
Originally Posted by quicky06
No can't feel it in the pedals.
02-13-2006, 06:13 AM #9
Brake problems you will only feel when you brake.
Question: steering wheel shake
By tc86gn in forum General HelpReplies: 17Last Post: 08-12-2015, 05:41 PM -
Wish this was my steering wheel...
By allbaugh_04 in forum Almost Anything GoesReplies: 6Last Post: 08-23-2011, 07:47 PM -
Tire pressure and wheel shake
By Sarge in forum GTOReplies: 9Last Post: 06-26-2009, 04:59 PM -
Steering wheel shake at over 50???
By AB'sLs1 in forum General HelpReplies: 15Last Post: 06-10-2009, 03:18 AM -
Shake in Steering Wheel
By joliver2 in forum Suspension and HandlingReplies: 3Last Post: 10-13-2008, 03:44 PM
