Results 1 to 15 of 15
Thread: Auto tans problem.
10-24-2008, 02:03 PM #1
- Apr 2008
- Fairhope, Alabama
Black- 2002 Camaro SS SLP
Auto tans problem.
I have an a4, and my problem is, from 1st to 2nd, when floored, most of the time it will slip, or ''red line'' before it shifts. Took it to a dealer, they said it looked fine, they reset the timing to stock, and updated it via computer. ''Stock timings before hand anyway'' And now it seems like when it shifts, it makes a sound like the clutch is worn, well if that's what u call it in a auto, how can i tell if the ''clutch is worn in a auto''? Im going to take it back before my miles expires the warranty and get them to fix it.
Thanks2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
10-25-2008, 09:38 AM #2
- Apr 2008
- Fairhope, Alabama
Anyone?
10-25-2008, 09:47 AM #3
i really wouldn't know man, but i do understand about flooring it part....so i've tried to not floor it, haha.
10-25-2008, 09:49 AM #4
- Apr 2008
- Fairhope, Alabama
I didn't get a ls1 to half ass it!!
10-30-2008, 03:54 PM #5
- Sep 2008
- Kitimat Bc Canada
that is because the torque convertor input rpm is not equal to the output rpm, so it's acting like a slipping clutch.
10-30-2008, 08:11 PM #6
- Apr 2008
- Fairhope, Alabama
How can this be fixed?
10-30-2008, 10:05 PM #7
- Oct 2007
- Beaver Dam KY
Its either a major tuning issue or your tranny is gonna take a shit
MINE IS DOING THE SAME THING...
stock tune and converter etc
right at 154k, changed fluid at 140... thick and black with lots of metal...
11-02-2008, 05:46 PM #8
- Aug 2007
- Texas
yeah, go to a shop and get them to flush your tranny and converter. when you drop the pan to service it, you only dump out 4 old quarts, a 4L60E holds 15, when they flush it, it cleans out the whole system, tranny and converter. should cost about $125 and take a few hours.
11-02-2008, 08:23 PM #9
- Apr 2008
- Fairhope, Alabama
^already did that.
11-02-2008, 09:24 PM #10
- Aug 2007
- Fort Worth, Tx
Black- 2002 Camaro Z28
try manual shifting it at around 5200, if you dont want to do that, let off the gas a lil before gettin to the redline.
11-02-2008, 09:25 PM #11
- Aug 2007
- Fort Worth, Tx
drive around it. i do.
11-04-2008, 09:53 AM #12
- Mar 2007
- NC
NBM- 1998Z28
The problem can be compensated for by a tuner by changing your shifting parameters tables in the CPUs program. But I'm afraid your tranny is about toast. I went thru the same thing until I gave up and bought one of Performabuilts Stage 2 4L60es. I had mine built by the locals and after a month or two it was the same crap all over again. So I say take the car to the local dragstrip and see how it holds up. If its gonna go out you might as well get it done under warranty. You can also try running an extra quart of fluid in the 4l60e. I've seen mixed results but it might work!
11-26-2008, 02:37 PM #13
- Feb 2008
- iowa
red- 98 trans am
Tranny is fucked.You either have something wrong with valvebody of tranny or clutches are toast? Either way take it to dealer and fix it!!
11-26-2008, 03:22 PM #14
- Apr 2008
- Fairhope, Alabama
The dealer wont touch it unless they can recreate it.. and it never does it when i want to..
11-26-2008, 09:35 PM #15
- Oct 2007
- Beaver Dam KY
Find someone with a data logging program and log that data and save it and show the dealer
Problem with Lumina VY SS Auto
By F1carbon in forum Automatic TransmissionReplies: 3Last Post: 11-05-2010, 08:04 AM -
Tans help!
By 02sunsetorangeZ in forum Manual TransmissionReplies: 10Last Post: 03-31-2010, 04:43 PM -
99 tans am = 3rd gen?
By Justin23454 in forum Firebird / WS6Replies: 5Last Post: 08-10-2007, 07:45 AM -
94 z28 auto-transmission problem
By tds1213 in forum Automatic TransmissionReplies: 2Last Post: 07-19-2006, 10:05 AM -
shifter problem with auto
By got-a-ls1 in forum General HelpReplies: 6Last Post: 04-09-2006, 04:08 PM
