Results 1 to 10 of 10
Thread: ford 9"
10-31-2008, 01:31 AM #1
ford 9"
I wanted thoughts and opinions.
I have an old ford 9" out of a 66 mustang laying here and had the thouht of possibly working it under the goats backend by fabbingup a 4 link or ladderbar setup.
reason for doing so, strength, weight reduction and maybe help traction.
do you think it would be a plus or minus for racing. I didn't buy the car for a plush comfy ride.
10-31-2008, 04:25 PM #2
Yes, It will give you strength and and elimate whell hop with the four link set up right. It will be a lot of work and a one peice drive shaft will be a must. You will also need frame stiffiners. If it is going to be a race car IMHO you are on the right track! good luck
11-01-2008, 03:18 AM #3
11-01-2008, 11:14 AM #4
That should complete the package for sure!!!!!!!!!!!!!!!!!!
12-20-2011, 07:28 AM #5
Over 3 years later, and I'm finally doing it..... Ford 9", 4 link suspension, tubbed with 31-18.5 15s on 18" wide Crater ss 15's
Rear subframe is pretty much done, 9" rear is mounted to the subframe, one wheel widened with a tire on it.....now its just about time to start cutting out the rear floor and wheel wells to fit the new subframe (hope to test fit this weekend)
12-20-2011, 08:26 AM #6
For one, a 66 stang did not come with a 9 inch, unless someone put it there aftermarket.
And it wont affect the ride in your car, because it still require all of your suspension.
12-20-2011, 10:09 AM #7
Your right about the 66, it was an 8"......but I ended up getting rid of the 8" and going with a later 9".....I think I should be VERY happy with the end results. With almost a total of a 40" contact patch I hope my traction problems will be over lol
Also dropped a locker and 4.56 gears in the rear
12-20-2011, 01:39 PM #8
- Jan 2009
- North Jersey
I hope you are going to post
12-20-2011, 08:53 PM #9
12-21-2011, 02:20 AM #10
All the old brackets cut off the rear end the new brackets welded on.
Widened 15 x 18" crager ss's
New rear subframe with wheel and 31-18.5 15 tire mounted
Fully adjustable 4 link bars
My son in one of the new tires lol
Camaro ZL1 Chief Engineer says "You're Welcome" to Ford Must
By Ed Blown Vert in forum General Help - 5th GenReplies: 0Last Post: 11-18-2011, 11:40 AM -
Question: Ford 9"
By 97txaggie in forum DrivetrainReplies: 8Last Post: 11-07-2010, 05:37 PM -
Detailed 1999 Ford Taurus AKA "The Princess"
By third_shift|studios in forum Showcar and DetailingReplies: 11Last Post: 10-22-2009, 07:32 AM -
ford 9"
By onebadassws6 in forum DrivetrainReplies: 6Last Post: 03-07-2006, 08:31 AM -
Ford 9" Swap
By jimbo98z in forum DrivetrainReplies: 0Last Post: 02-13-2006, 02:26 PM
