Results 1 to 18 of 18
Thread: fake A6?
04-10-2007, 05:13 AM #1
- Pittsburgh, PA
fake A6?
I've been talking to "malsop" on here, he's the guy with the red t/a from Bullrun on spike tv. He might custom build me a ws.7 and I inquired about an A6 b/c i do so many road trips with the car. he said:
We'll hook up a th400 with a "gear vendors overdrive unit" that replaces the current tailshaft on this trans and bingo 6 speed auto. I think the 700r trans is the 4-speed unit and I guess I am not aware of any other 6 speed applications. But I may be a little old school?
So do you think something like this would work if tuned properlly or will it suck? any body know the gear ratio after the conversion
Custom Car Emblems from third_shift|studios
jaison tortorea
04-13-2007, 12:51 AM #2
just wait untill the 6l80e comes out
04-15-2007, 07:15 PM #3
- Apr 2006
- Northern Kentucky
Pewter- 2000 Camaro SS
I think the TH400 + GVOD is the best option if you have the money. It's sweet.
04-15-2007, 07:16 PM #4
- Apr 2006
- Northern Kentucky
04-19-2007, 12:17 PM #5
- Feb 2006
- MD
1. It won't fit. It's WAY to big for the trans tunnel.
2. If you somehow cut the shit out of the floorboards and got it to fit, you'll still have a problem with the speedometer and rear suspension. You will not be able to connect the torque arm to the transmission like stock. Nor will you be able to connect it to the crossmember like many aftermarket pieces.
3. It's a pointless gas saving/cost cutting idea. The TH400 with converter (assuming cheap junk), overdrive unit and everything necessary to install it will run well over $3000 just for parts alone. Then you have to fabricate floorpans and a rear suspension.
04-19-2007, 04:31 PM #6
y not get a m6? i get like 26-28 mpg on the interstate! if you keep it around 70-75mph you get killer gas milage.
LS7 clutch,01 slave,Corsa 3" stainless exhuast,drilled/slotted rotors + ceramic pads,160 thermo,Mti clear lid,msd 8.5 wires & Ngk plugs...more to come!
www.cardomain.com/ride/2311455
04-19-2007, 06:13 PM #7
they have a hugh site, and this is the best/only option really to get a 6 speed out of it.
04-19-2007, 06:16 PM #8
- Apr 2006
- Northern Kentucky
04-19-2007, 06:19 PM #9
who are you?? have i seen you around before??
04-22-2007, 05:53 PM #10
04-22-2007, 05:56 PM #11
04-22-2007, 05:58 PM #12
04-22-2007, 07:04 PM #13
www.myspace.com
mike alsop
lafayette indiana
www.raisor.com
04-22-2007, 07:10 PM #14
04-22-2007, 07:15 PM #15
isn't the trans am your daughter's car?
04-22-2007, 07:57 PM #16
I've heard nothing but good things about gear vendor overdrive units. I have never heard of one in a 4th gen f-body mostly because they already had overdrive it them from the factory unlike alot of the 60's-70's cars there usually in. I say if you have the money go for it but be sure to post some pics when its done.
05-02-2007, 07:08 PM #17
- May 2006
- san diego
silver- 1998 camaro z28
Also remember that a 4l60e is a dwarf in comparison to the Th400/GV combo... If you're going to be putting down big numbers this is definitely the way to go... The GV are good for somewhere around 2500 hp...If you get a TH400 really built then you could have a decently cheap 1000rwhp capable tranny combo... A 4l80e can be built for for this BUT they are somewhere around $5k if you go with one that can handle the abuse...
05-03-2007, 04:34 AM #18
- Apr 2006
- Northern Kentucky
Not if you get the parts and build it yourself. Or have a local builder build it with good parts.
this HAS to be fake....
By third_shift|studios in forum Almost Anything GoesReplies: 11Last Post: 10-06-2009, 09:17 AM -
This has to be fake
By screaminbird in forum Kill StoriesReplies: 8Last Post: 10-21-2008, 11:27 PM -
FAKE SSs!
By 7camaro7 in forum Camaro / SSReplies: 126Last Post: 09-02-2007, 10:24 AM -
this has to be fake
By ss~zoso~ss in forum Multimedia SectionReplies: 5Last Post: 08-29-2006, 09:45 AM -
Are they fake?
By kemp in forum Firebird / WS6Replies: 5Last Post: 05-17-2006, 08:59 AM
