Results 1 to 20 of 20
    Black T/A's with drag wheels
    Looking for pics and description.
    Thanks in advance.
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Black/Screaming Yellow
    99 S/C TA WS6 & 04 Cobra
    Here are mine!
    1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
    10.29@129 w/1.60 sixty foot
    2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    The rears are 15x10 with 7.5" backspacing and no I didn't roll the fender lip. Haven't had to yet. The fronts are 15x3.5 with 1.75" backspacing. I had to remove the bumpstops and clearance the calipers a little. The rear tires are 27 x 11.5 Hoosier QTP's.
    How does it hook??
    Reason being it seems the 10" rears seem to be much more expensive. Is that extra inch worth it??
    I am finally looking to toss a 12 bolt under mine, and I would like to have a set of drag only wheels/tires.
    Not looking to set records, just to get her out of the hole.
    Lowered, HID's, tinted.
    Mar 2003
    Melbourne, FL
    How does it hook??
    We had a terrible time at the track last night but I'll give you an update once we get a few of the bugs worked out.
    Anymore???
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    In a few days I will take some more.
    Thanks!
    Ordering my rear end soon, and would like to have some idea of what light wheels to toss on with the drag set-up.
    I think I like those.
    SLIKWS6
    Guest
    You think you like those, I love them, so please wait until I have them.
    JK, personally the weld prostars, look the best.
    Pretty much what I was thinking.
    I don't need to hook up a ton of power, but I want to make sure I get wide wheels. And there seems to be a pretty big difference in price from 9" to 10" wide wheels.
    9" enough??
    Michigan
    1997 Chevy Corvette
    Very nice!
    SLIKWS6
    Guest
    Im pretty sure the weld prostars come in 8" and 10", not 9", and the difference is about thirty bucks, Id check jegs.
    Marylandistan
    2001 Trans Am (sold)
    15x8 weld Prostars. [IMG] [/IMG]
    Member 94 Formula's Avatar
    La Mesa
    M3 SMG 350HP
    Here is one of my 94 Formula.
    La Mesa
    M3 SMG 350HP
    Here is one more I found of my 94 Formula.
    The rims and tires are for sale for $800.00 for everything if anybody wants them.
    15x4 with new 165-R-15
    15x8 with MT Et Street drag Radials. "90% tread left"
    Dustin
    Those don't look bad either.
    Currently looking for just the rears. Actually think I have them picked out. ProStar 15 x 10 x 7.5.
    Trying to find some used as I have time before I could run them anyways.
    How much grinding is required on the rear calipers?? What did you use to grind?
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    It depends on if you want to use a spacer or not. If you use a 5/16 spacer the grinding is minimal, 3/16 spacer you have to grind more, and if you use no spacer then the grinding is pretty heavey and you have to be sure you do not grind into the brake fluid passages which would ruin your caliper. Iused an angle grinder. It worked great took me about a half an hour per caliper!
    Marylandistan
    No spacer on the rear used here. Took at least an hour per caliper. I use 5/16 spacer on the fronts.
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Here are some more pics as promised! Sorry but it took me awhile to take them...
  1. Black SS, Black Chrome wheels, Matte Black stripes
    By Quarterracer in forum Appearance Section
    Last Post: 02-11-2009, 03:39 PM
  2. Question: best drag wheels?
    By 0verkill in forum Wheels and Tires
    Last Post: 08-24-2008, 10:01 AM
  3. Black sun. drag races in St Louis
    By LS2Tuner in forum Drag Racing
    Last Post: 09-21-2007, 10:16 AM
  4. Pics of black Camaros/Trans Am's with black wheels
    By blacklightning01 in forum Wheels and Tires
    Last Post: 09-20-2007, 05:40 PM
  5. black ccw drag pack
    By skinnies in forum Parts For Sale / Trade
    Last Post: 06-30-2006, 10:21 PM
