Results 1 to 3 of 3
Thread: Door Handle Quick Fix
05-08-2011, 10:42 AM #1
I was out returning videos to Blockbuster, tried opening my door handle and heard a thunk and the handle quit working. SOB!!
The rod came loose and popped off.
So inside the door we go:
Tools:
#2 and #3 cross tip screw drivers
zip ties
Step 1: grab a beer or two or am I
Remove these screws off the door panel
Remove the these and disconnect the wire harness.
Next gently bump the bottom of the panel to pop it off the door.
Remove the plastic and sit in an area away from windows paint or anything that could stick to it.
Step 2:
Place the rod back into the hole, I then used 2 zip ties to secure it into place but not so tight that it prevents the function. One zip tie went around the rod and lever and the other went in between the the rod and lever around the zip ties so that it would not come off. Sounds confusing but if you look at the pic you can make it out.
Trim off excess and work the handle. Open and close the door several times to make sure it works.
Step 3: Re-install the door panel, reversing above steps.
05-08-2011, 11:52 AM #2
- Jul 2009
- North of the Motorcity
Nice!
Productive today, Huh?
05-08-2011, 01:01 PM #3
yeah you could say that.
I had to sneak it in while wife is at work, now I'm working like mad trying to fix her a nice dinner.
Door handle question
By SMWS6TA in forum General HelpReplies: 5Last Post: 08-04-2011, 11:41 AM -
broken door handle
By tigersport14 in forum General HelpReplies: 4Last Post: 12-22-2008, 10:21 AM -
FS: 98-02 LS1 Tensioner & door handle bezels
By MagicMan in forum Parts For Sale / TradeReplies: 0Last Post: 09-10-2006, 03:44 PM -
WTB: Door handle bezel
By MagicMan in forum Parts Wanted / TradeReplies: 3Last Post: 09-03-2006, 08:26 AM -
Door Handle Lights
By 99WS6MAN in forum General HelpReplies: 7Last Post: 02-15-2006, 09:59 AM
