Results 1 to 20 of 37
Thread: whats my rwhp?
06-20-2006, 08:20 AM #1
- May 2006
- minneasota
black- 2001 Trans am ws6
whats my rwhp?
i plan on going to get my car dynoed i was just wondering what i can expect?i have a 10 over bore with forged dimond pistons proformance hot cam dynatech headers and 3inch flow master cat back system.would apreciate the feed back thanks.
06-20-2006, 05:03 PM #2
- Thornton, CO
375 RWHP.
Is it tuned??2008 Trailblazer SS
Lowered, HID's, tinted.
06-21-2006, 05:16 AM #3
- May 2006
- minneasota
ya it was tuned by a place called- TPIS- in chanhassen Minneasota they are very good.
07-04-2006, 04:12 AM #4
then why dont you know the hp?
07-05-2006, 05:14 AM #5
- PA
Grey- 2003 Mach 1
07-05-2006, 05:28 AM #6
because most places do not tune on a dyno
07-05-2006, 06:21 PM #7
- PA
Grey- 2003 Mach 1
07-05-2006, 10:01 PM #8
07-06-2006, 04:16 AM #9
nope around here by me at least you got to pay a whole hell of a lot more for a dyno tune. mine was tuned on the street
07-06-2006, 08:45 PM #10
Agreed, while dyno tuning is obviously beneficial, here in SC, up until about a week ago, the only option was a street tune. My car was dyno tuned in NC about 3 hours away. Even with the local place now, it's a guy using another guy's dyno, so of what I think is a $400 charge, I'm paying the guy to pay someone else. I enjoy a good tune, and it's typically good hp/$ but $400 for an hour or two of no-sweat work?
Apparently I need to get in the dyno tuning business
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
07-19-2006, 11:33 AM #11
- May 2006
dyno tuning is the way to go
07-19-2006, 04:40 PM #12
- Jul 2006
- Princeton, NJ
Dyno tuning is great if all you ever do is leave your car in 1:1 gear and expect to get 0mpg.
Dyno tuning (none motored) is a tool for tuning but what is most important is how the vehicle performs in the REAL world. Some might like to brag about their rwhp numbers, others their gas milage, and some stick to the good old 1/4 mile. For me, it's a blend of the last 2. Street tuning gets you the mpg and mannors while 1/4 mile tuning gets you the ET. The dyno can be for all you bench racers. Keep in mind you do NOT need a dyno for a wideband o2 reading. Running a wideband at the track and watching each gear change your AFR can be a real eye opener towards why dyno tuning isn't the end all be all tune.
Dyno tuning will get you -90 to 90% of perfect and the rest is on the street and track.
D-millar, the cam and headers probably got you to 360+rwhp. The bore, pistons, and cat-back are feather weights. Tuning might get you 380+, no way to be sure but who cares? Just take it to the track and get a feel for it. It's a lot cheaper and TONS more fun. Then, post your vehicle weight, the conditions, and your mph. Compare with those that have both track time and dyno numbers. See, you saved some bones and had fun. Later
07-19-2006, 05:00 PM #13
- May 2006
- minneasota
thanks for the advice guys! i just got back for racing and my car ran a 13.0 at 105mph the conditions where hot! and i had some horiable short times but still had a blast.
08-06-2006, 11:24 PM #14
Your concept about tuning for a mix of gas mileage and 1/4 mile performance is very interesting. The next time you are at a National meet remember to tell John Force, Greg Anderson and all the other top competitors that they are wasting their time tuning on dynos. I am sure thay will listen to you and appreciate all the money, gas and time you will be saving them. BTW, what method do you use to tune your car? And how exactly do you do it? After each run? What tuning changes do you do between runs if that's what you do?Michael
In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) 10.89@127.57 on street tires, Race Weight 3,640 lbs
08-06-2006, 11:43 PM #15
Last edited by GA Country Boy; 08-06-2006 at 11:48 PM. Reason: Added some more info
08-20-2006, 05:17 PM #16
- Dec 2005
- Ms
Stock our cars are 350@ the flywheel.
08-21-2006, 10:21 AM #17
What altitude are you at? Plus hot weather makes the actual density altitude worse. If you are not at sea level you won't be seeing actual full horsepower potential from your engine in the real world due to less volumetric efficiency, where as the chassis dyno results are corrected figures that consider altitude power loss with other factors to generate a corrected rwhp figure. So therefor your mile an hour at the track will give you a calculation of how much hp your making at the given density altitude in real world conditions. Where as the chassis dyno gives you max rwhp readings based off an idealized correction factor that compensates for density altitude. The dyno is a good reference for tuning and comparing performance gains from upgrades, but the track is also very beneficial too for tuning if you have the resources. I say just take your car to the dyno and see what she'll do! Plus run at the track and have a good time.
08-21-2006, 10:31 AM #18
Good points, but also remember we are talking about mostly daily driven street/strip cars on this forum, not super dollar 4 second drag cars. I think it's safe to say that tuning methods between the two have considrably different factors involved albeit similar methods for testing and tuning(dyno,track). Plus John Force and the top fuel and funny car guys and everybody does do there final tuning on the car based on data from the track runs, hence the use of super high dollar data logging equipment utilized during track runs. Because the car does respond differently in the real world vs. the dyno. I think its safe to say that under ideal circumstances an individual or race team for that matter, would be best benefited to be able to utilize tuning under both dyno and track conditions. However not every average ls1 hot rodder, or any other for that matter, has the resources and or equipment and money to tune an efi setup on the dyno and at the track.
08-21-2006, 11:21 AM #19
What cars are "our cars"?. I see members here with Trans Ams, Z28's, '70 chevelle, Mustang, vettes and others (you don't even tell us what you have). Do they ALL have "350hp@ the flywheel"?The initiator of this thread has a 2001 Trans Am ws6 and that's what I was referring to which was advertised at 320 hp, but went to 325hp in 2001.
08-23-2006, 01:14 AM #20
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
I need to get 500 rwhp
By silver35thss in forum Internal EngineReplies: 10Last Post: 07-18-2009, 01:28 PM -
whats my rwhp
By mr_r0bert0 in forum Dyno InformationReplies: 41Last Post: 11-07-2008, 06:27 PM -
want 350 -400 rwhp
By 2002 LS1 in forum Internal EngineReplies: 21Last Post: 06-24-2007, 04:46 PM -
550 RWHP 383 Z06 VS 770 RWHP Supra MKIV
By LS1 RX7 in forum Kill StoriesReplies: 6Last Post: 02-02-2007, 04:47 PM -
257.8 rwhp, whats wrong with this junk...????
By redz284u in forum Dyno InformationReplies: 26Last Post: 02-22-2006, 08:38 PM
