Results 1 to 20 of 21
02-12-2010, 10:13 AM #1
- Jan 2007
- Charlotte, NC
Sebring Silver- 2002 Camaro Z28 6M
Post LT header install header issues
I just installed BBK long tube headers and y pipe, really woke the motor up, but I have two issues; (1) right side header vibration during idle ONLY, and (2) check engine soon light is on. Feedback please.
02-12-2010, 10:43 AM #2
02-12-2010, 12:31 PM #3
02-12-2010, 12:41 PM #4
Any chance you have a heat shield vibrating? After installing our catback, the rear heatshield just in front of the axle picked up a resonate vibration.
02-13-2010, 05:13 PM #5
Question on the cat subject of this thread, would cats solve the ses light? High flow cats to be exact?
02-13-2010, 05:20 PM #6
i dont think so its best to just get a tune. frost can get you done for $125. your car is rich now from the install and you will get more out of them with the tune.
02-13-2010, 05:24 PM #7
if you run cats and keep the rear o2's your light should go out.
02-14-2010, 06:00 AM #8
02-14-2010, 07:50 AM #9
So even if you get new cats and still keep the rear o2's it still will throw codes then? So as long as the PCM is retuned and you dont have to pass a visual emissions, your fine then? (not a cali resident)
02-14-2010, 03:42 PM #10
Yes, if you don't have a visual and they don't freak at the no-cat smell of the car, you should be fine. A tune can make it pass OBD II inspection no problem.
02-14-2010, 04:14 PM #11
cool. So ill just for go the cats and get the tune alone then
02-14-2010, 04:32 PM #12
02-14-2010, 04:57 PM #13
Yup, decent tuners know how to do this. They eliminate the trouble codes from reporting errors for the disabled or failing emissions equipment such as rear O2s. The readiness monitors still report as ready so it appears you have rear O2s still. But no trouble codes appear for whatever is tuned out, and your car passes emissions. Pretty trick stuff!
Hit up Frost site sponsor, he can hook you up with a tune or find a reputable local GM tuner.
02-14-2010, 05:22 PM #14
02-14-2010, 07:47 PM #15
So If I add highflow cats in and still delete the rear o2s out, the cats still burn the unspent fuel?
02-16-2010, 01:56 AM #16
Yes the hiflow cats still work fine whether you have rear O2s or not. The rear O2s only monitor the effectiveness of the cats.
You need to have cats if you have a visual inspection, although they are moved from stock location so technically they are illegal anyways. I chose to have a catted Y to cut down on noise and fumes, but it is your choice based on those considerations.
02-16-2010, 08:19 AM #17
The OBD II code for this is P0153 right?
02-17-2010, 06:30 PM #18
- Jul 2006
- Tyler,Texas
Black on Black- 2001 Trans Am ws6
your vibrations are from the primary tube being pressed against the k-member. happends all the time. just notch it
02-18-2010, 07:44 AM #19
so the $37 highflow cats off ebay would be fine to add? All they gotta do is cut down on some of the unburnt fuel and smooth out the exhaust note a bit right?
02-18-2010, 04:04 PM #20
Yes probably works just fine, and the price is dirt cheap. I'd try it FWIW.
Post header install questions
By UH60Driver in forum External EngineReplies: 4Last Post: 09-16-2010, 01:05 PM -
Help: Header ground clearence issues
By BRICKYARDDTX in forum External EngineReplies: 15Last Post: 10-17-2009, 05:28 PM -
header install so cal?
By sscamed in forum External EngineReplies: 0Last Post: 10-26-2008, 11:18 PM -
help please with header install
By Z28LS1 in forum External EngineReplies: 12Last Post: 01-07-2007, 06:04 PM -
header install
By bad@ss mike in forum External EngineReplies: 6Last Post: 03-29-2006, 06:03 AM
