    Member Speed_kills_WS6's Avatar
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    Exclamation TERRIBLE Gas mpg
    So I'm new to this forum, but have been reading up on material for weeks. I had a 98 TA A4, averaged about 19 mpg around town, 28 on the highway! Upgraded to a 02 WS6 M6, gas mpg about 15!!!! I don't drive like a bat out of hell all the time, so I can't figure out what my problem is. Correct me if I'm wrong, but shouldn't I be getting the same if not better mileage as an A4??
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Your mpg may be thrown off without your knowing due to a different gear ratio. I also have an m6 and can get anywhere from 10 to 29 mpg. All depends on what rpms you shift at.
    car seems to run fine though? Any soot in the exhaust tips? There will probably be some soot but does it look excessive? Any mods on the car?
    The Demon Demon_Z28's Avatar
    Feb 2008
    WA
    Bright Rally Red
    could be running very rich causing you to use a lot of gas...might want to get your emmision equiptment checked out, PCV, EGR, Air and ect... or lack of airflow will cause a rich air/flow mixture resulting in bad gas mileage.
  1. Help: Terrible gas mileage!!
    By flybird in forum V6
    Last Post: 08-04-2013, 07:41 PM
  2. What a terrible story :(
    By FasstChevys in forum Almost Anything Goes
    Last Post: 06-30-2010, 06:43 PM
  3. Terrible Dyno
    By 99formulals1 in forum Firebird / WS6
    Last Post: 04-25-2008, 09:30 PM
  4. how terrible are the OBX headers?
    By allforspeed in forum External Engine
    Last Post: 07-07-2007, 03:12 AM
